Old 24th November 2010, 08:19 PM
m3csl m3csl is offline
Default double glazed windscreen
hi all..can someone tell me if the windscreen on a d2 s8 is double glazed because my my snooper 3zero radar detector cannot pick up satelites when sat on the dash.
regards
M3CSL
Old 24th November 2010, 08:27 PM
All but the cruddest of micra-mobiles have twin pane laminated windscreens, so yes, it does, but the pre facelift S8 had a special layer in there for some reason made of god knows what which basically prevents pretty much any radio signal getting into the cabin....
Fortunately, they changed the glass after 1999 so now phones / gps etc all work fine !
Old 24th November 2010, 10:12 PM
I think the problem coating is a metallic layer deposited onto the glass (Inside the sandwich). The idea being to reduce the greenhouse effect inside your car.
All your windows will have this and, sorry Ian, but I could barely get my Garmin to work inside my 2002 S8. Opening the roof/windows cured it though
Old 24th November 2010, 11:10 PM
Athermic glass if the name I beleive.
And sadly, not just the '8s had it. You see quite a few cars with that funny couloured windscreen. Manufacturers got wise to it and started to put an unprotected area around the mirror for GPS etc to be stuck on
Old 25th November 2010, 04:44 PM
So theres no way to use a gps radar dedector
Old 25th November 2010, 07:13 PM
Re-radiating GPS antenna. Put it in the boot, or under the wiper grille cover, then run the cable into the car and away you go.
Conan has one, though I think he's since put the gubbins into the position of the original GPS aerial as he uses TomTom.
Old 25th November 2010, 07:34 PM
Yup. Bought one of these and spliced it into the ariel on the boot. Works a charm and can run multiple GPS units of it.
Old 26th November 2010, 05:42 PM
I had heat reflecting windscreen on my 1997 S8 and GPS did not work unless I stuck it to the drivers door side window which have been replaced with normal window. Windscreen was in the bad shape witl lots of scratches, pits and chips, I was lucky enough to get a brand new Genuine Audi windscreen from facelift A8 for £40 on e-bay( best offer down from £50 buyitnow ).
Old 5th April 2017, 09:50 PM
RS6's Avatar
RS6 RS6 is offline
im having the same problems with anything GPS can't use my snooper at all
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
