#101
#102
Good spot Sean
![]() Did the drive plate bolts and the starter this morning New spark plugs Not sure if I've shown this tensioner trick before. The V8 tensioner is only available as a complete unit for £80-100 depending on brand, but the tensioner part itself is always fine. Its only ever the roller which wears out. So, remove the roller and acquire one from a Hyundai 2.7 ![]() The Hyundai roller doesn't have the moulding to take the plastic cap from the original roller - instead it has this washer which goes under the bolt head. The washer has a 10mm hole though, and we need a 12mm hole... Embiggen the hole with the step drill. Don't try and do this with a twist drill as it will grab and spin the washer. A step drill is much better for thin stuff. Attach the new roller with the modified washer and original bolt Back on the engine and running smooth again but for £22 instead of £80. The clips for the header tank hose have dug in to the rubber. I don't have any spares of this hose as its a very common problem. The hose isn't split though, so the area is protected with heatshrink sleeve. Wiring harness back in place The subframe is pretty grim! Elbow Grease and the pressure washer mades short work of cleaning it I stopped early for the Formula 1 so the engine and gearbox will go back on the subframe tomorrow, then after cleaning the engine bay it can all go back in ![]() |
#103
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
#104
Cleaned the engine bay, cleared out the scuttle panel and drains etc.
Hard to capture matt dark green with my phone camera, but its nice and tidy now and ready for the engine to go back in tomorrow. |
#105
It’s such a difficult colour to capture without direct sunlight. It can go from a very obvious green with flecks in it, to a matt looking green to pretty much black at night.
I’ve seen inside the bay enough times to be able to see it’s far cleaner now than it’s ever been in my ownership ![]()
#106
Apologies all, for the lack of updates. I have a habit of pressing 'preview' instead of 'submit' which, followed by a few late nights to finish the car off meant I got a bit behind
![]() Clean gearbox mounts probably don't make the car run any better, but they do make it nicer to work on ![]() Exhaust manifold bolts replaced with stainless Engine back in The subframe locating pins mean that I haven't lost any of the front wheel alignment which was done in phase 1 of the project, as I set the subframe with these before that was done. The right hand cam belt cover was cracked and I don't have a spare so this was repaired with specialist adhesive. These covers are nylon which is very difficult to glue as it has low surface energy so traditional adhesives don't stick to it. This was a bit of an April Fool's trick on me! I spent a good 5 minutes trying to work out why the intake tube wouldn't sit right before I discovered it was previously on backwards ![]() The coolant breather hose was repaired with a brass tee piece. I might do them all like this tbh as this is much more robust than 20 year old plastic. New front snub mount in place. This one originally had two 2mm shims under the bracket, but needed my last 1.5mm shim to sit flush with the new mount. I'll need to get some new ones laser cut for future projects. This single picture represents a full day's work! ![]() Home stretch now - all the engine bay back together ready for the the front panel Front panel in place and ready for its first start and warm-up Up to temperature and you can see the cam phasing on the lower right - zero degrees deviation between banks 1 and 2 relative to the crank ![]() ![]() ![]() This is the witness mark in the bottom of the bumper from the event which killed the front panel. This lines up exactly with the thread on the lower radiator mount, and there is a corresponding ding on the inside. All back together and looking smart The final job was a brake fluid swap - as you can see, its a little past it's best! It should be changed every 2 years, but they are pretty much all in this state the first time I see them. I think most garages are wary of touching the braking system on the D2s, and with the Brembo calipers tbh its not that surprising since if you don't regularly exercise the bleed nipples they seize solid in the calipers and then you need a caliper refurb to change the brake fluid ![]() Before: After flushing 250ml through each caliper Just back from a most enjoyable road test ![]() and thats it! The Green Beast is safely home and on her original (now repaired) wheels, and back to waking up the neighbours ![]() |
#107
excellent work as always
#108
But are they?
I always take mine off my cars before I send them for any work, though going to MJ that might be considered an insult..... ![]() Last time I looked those FL caps were readily available anyway.
#109
Brilliant work (as usual) and the engine bay looks almost like new
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice ![]() |
#110
I knew someone would pick up on that
