Old 13th August 2021, 04:09 PM
Sit down, Waldo Sit down, Waldo is offline
Excellent!...that's another thing to add to the list then...my piggy bank's never going to talk to me again lol
Old 22nd August 2021, 04:05 PM
A bunch of bitty jobs this weekend to get the car ready for it's paint correction.
Removed the badges to make polishing the boot lid easier, and the rings were past their best so they needed replacing anyway. The antenna also came off as the grommet was ruined. I also took the left rear light out because it was leaking around the seal. I appear to have successfully solved that as it rained last night and the boot wasn't full of water this morning. More on that later once I'm sure it worked.
Taped off to do the rest of the brightwork. Some of it came back, some of it didn't, so I'll replace what's needed later on. It looks good enough for before and after pics of the paint restoration though.
Saturday afternoon did not go well The VDO pump I fitted last week wasn't holding pressure when turned off so it made starting quite difficult. I pulled that out and fitted a Magnetti Marelli unit which Mike bought a while ago to experiment with. That lasted ten minutes until it cavitated itself to death and the engine misfired and stalled. At £25, most definitely too good to be true Finally, I put in a known-good original pump and at last it worked properly. I'll fit another new VDO pump before it goes to its new home so the next owner has peace of mind, making four pump swaps in total
Sunday - pulled the last of the heinous mudflaps off
One of the parking sensors is not only unpainted, but superglued in to the bumper What sort of deranged thought process goes through the mind of someone to think this an acceptable repair? Not only did they glue the sensor in, but they dribbled glue all over the bumper so it looks a total mess
I was able to remove the superglue with acetone, since this is original 2k paint which was baked on so its quite resilient. The mid-right sensor was also faulty so two replacement sensors and brackets and it looks a million times better and now works properly again.
The stone guard on the left is utterly ruined so this has to go. Warmed up with the heat gun and it peels off relatively easily, and then a bit of tar remover to get the adhesive residue off
This is probably the best paint on the whole car For now anyway
Its now with Fiftyfive Details for Nicola to work her magic on it over the course of the next week or so. She is really keen to get started on the transformation, and Bert is going to shoot a bunch of before & after pics for a feature on paint restoration and etching in PVD magazine
Totals so far:
171 hours, £2472
Parts used:
PS hoses (refurb, £200)
PS hose brackets (used)
NSF upper rear arm (used)
NSF lower rear arm (used)
NSF wheel bearing (used)
CV boot (£12)
Suspension brace (used)
Boot lid (£150)
FE wheels (£500)
Window motor (£50)
Headlight level arm joints (£15)
Radiator (£300)
Belt idlers (used)
Accessory belt & idlers (used)
Snub mount (£60)
Air filter (£6)
Wiper mechanism & motor (£120)
Air box trim (£10)
Intake duct (£10)
Bumper (£200)
F125 (£1)
Exhaust clamps (£30)
Boot grommets (£15)
Brake fluid (£20)
Wiper trim (£50)
Platinum carpet (£25)
Central locking pump (£60)
Lateral Acceleration Sensor (£20)
N/S seat belt (£18)
Potions and microfibres (£120)
Wiper blades (£30)
Bosch S3 019 battery (£85)
Bosch lambda sensors 2x (£120)
Parking sensors 2x (£40)
SAI removal plates + map (£65)
Fuel pump (£140)
ID:	27035   Click image for larger version
ID:	27036   Click image for larger version
ID:	27037   Click image for larger version
ID:	27039   Click image for larger version
ID:	27040   Click image for larger version
ID:	27041   Click image for larger version
ID:	27042   Click image for larger version
Old 22nd August 2021, 06:05 PM
Default Lucky buyer!
One thing is certain. Whoever buys this car has more history than most any other car out there.
Old 22nd August 2021, 07:27 PM
GarethS8 GarethS8 is offline
Wow amazing as always, totally agree with the CoL above
Plus Way to Many others
Old 22nd August 2021, 08:28 PM
S81 S81 is offline
I'm assuming that any of the bright work that's gone milky will not come up ,and have to be swapped ?
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 22nd August 2021, 08:49 PM
Yes, the boot trim and the left rear bumper trim have totally failed - they're down to raw aluminium now and won't come back. Oddly most of the right side comes up really well but the left is still a bit dull so I'll probably remove most of the left stuff and have another go at it off the car. If it won't brighten up then I have plenty spare so I'll just replace it.
Old 23rd August 2021, 10:11 AM
First glance I thought you were getting ready for a track day and looking to reduce the drag co-efficient
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 23rd August 2021, 09:03 PM
More tape today
Old 23rd August 2021, 09:30 PM
Ronin Ronin is offline
Have the headlights been polished already?
Is there a trick to get the yellowness out of the lenses inside?
Old 23rd August 2021, 09:41 PM
I replaced them early on with an almost-new pair. The yellowing happens on the inner lens so they would have to be dismantled to get to that which is non-trivial on the FL2 version as they're glued together. Even once you got to the inner lens I'm not sure if anything could be done with it though, as its not available as a spare part. Maybe something I'll investigate in the future.
