Old 22nd August 2021, 07:27 PM
GarethS8 GarethS8 is offline
Wow amazing as always, totally agree with the CoL above
Plus Way to Many others
Old 22nd August 2021, 08:28 PM
S81 S81 is offline
I'm assuming that any of the bright work that's gone milky will not come up ,and have to be swapped ?
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 22nd August 2021, 08:49 PM
Yes, the boot trim and the left rear bumper trim have totally failed - they're down to raw aluminium now and won't come back. Oddly most of the right side comes up really well but the left is still a bit dull so I'll probably remove most of the left stuff and have another go at it off the car. If it won't brighten up then I have plenty spare so I'll just replace it.
Old 23rd August 2021, 10:11 AM
Taped off to do the rest of the brightwork. Some of it came back, some of it didn't, so I'll replace what's needed later on. It looks good enough for before and after pics of the paint restoration though.
First glance I thought you were getting ready for a track day and looking to reduce the drag co-efficient
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 23rd August 2021, 09:03 PM
More tape today
Old 23rd August 2021, 09:30 PM
Ronin Ronin is offline
Have the headlights been polished already?
Is there a trick to get the yellowness out of the lenses inside?
Old 23rd August 2021, 09:41 PM
I replaced them early on with an almost-new pair. The yellowing happens on the inner lens so they would have to be dismantled to get to that which is non-trivial on the FL2 version as they're glued together. Even once you got to the inner lens I'm not sure if anything could be done with it though, as its not available as a spare part. Maybe something I'll investigate in the future.
Old 24th August 2021, 06:12 AM
Surprised that they’ve not popped the grill out as it’s such a quick and easy job
Old 24th August 2021, 09:06 AM
I don't see any advantage in taking it out tbh. The polishing pads will happily work around the contours of where the grille and metalwork meet, and taking it out runs a very high risk of tabs breaking off. With it out, there's a gaping hole with sharp edges so you'd still have to mask it up anyway.
Old 25th August 2021, 09:19 AM
Whats in the Detailing Unit
Before - the centre of the roof is the worst area, which is probably to be expected
after wet sanding
after machine polishing
ID:	27078   Click image for larger version
ID:	27079   Click image for larger version
ID:	27080   Click image for larger version
ID:	27081   Click image for larger version
ID:	27082   Click image for larger version
