D2 - Interior Seats, dashboards, plastics, ventilation everything inside the cabin |
1996 was pre wired. 1997 they started making specific looms per car.
So early PF car, you can easily fit heated seats as all the connectors were there. Later, PF car, you will need to install the wiring to handle it. To find out, pop off the blanks on the dash where the heated seat switches should be. If there are connector blocks behind there, you're in luck. If not, you're not.
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
I am thinking about removing my FL D2 S8 seats to allow access for an interior deep clean.
Is there any more knowledge to impart or easy steps I need to follow for both removal and reftting of these seats. And what tools, such as size and shape of spanners, will I need? Will I need the radio code given I'll be disconnecting battery (hint: I don't have it...) Apart from cleaning, any other jobs it'd be useful to do while the seats are out?
2002 Mark's D2 S8 FE 2020 BMW M340d xDrive (Anely's daily driver) 2000 FL D2 4.2 QS - SOLD 2011 ![]() Last edited by sarg; 18th February 2022 at 10:05 AM. |
Power the headrests all the way down and then a sharp tug up will disconnect them from the mechanism, then remove them.
The plastic trims on the base have a tang in the middle which holds them to the mechanism. Push them 'on' a little more and lift the tang with a pick, then slide them off Power the seat all the way forward and remove the rear bolts (T45 torx) 17mm spanner for the seatbelt Power the seat all the way backward and lift the front up all the way then remove the front bolts Tip the now loose seat backward and you can reach under the front to disconnect the wiring The wiring harness is clipped to the base of the seat. You can reach round to the back of the panel and squeeze the two tangs of the clip together and pop it out. I always put a towel over the sill before removing the seat as it is heavy and difficult to handle and easy to damage the trims. Don't lift by the switch panel as it will break. You can lift from under the front bolster though. I never bother disconnecting the battery as all the airbag connectors will short themselves out as soon as they are disengaged to avoid any stray currents or static doing anything bad. You could disconnect the battery if you really want to, but the system is all shut down with the ignition off anyway. Just remember not to turn the ignition on with the seats disconnected otherwise it'll throw an airbag code and you'll need VCDS to reset it. If you do lose the radio code you can get it from onlineradiocodes.co.uk for £20. |
I managed to find a nice set of sport seats but from facelift D2, anyone (@IT) know if the connectors are the same on both pre-facelift and facelift models?
Note that FL leathers are different colours and textures to PF. Black PF is darker than Black FL etc. You will need to change the armrests to match as it will be obvious, and door cards might show it too depending on the trim of your car. The tricky bit, is that the rear FL seats differ quite a bit as they are designed for a 3 point middle seatbelt, not a lap belt, so they might not swap in so nicely, and if you have PF rears and FL fronts the colour match will be awful imo.
@IT - thank you very much sir. I’m glad the basic power and memory are the same connectors. I already got the FL armrests so hopefully I’ll manage to fit the rears nicely. And I’m not worried about the color because my dashboard and door cards are dark blue almost black and the seats are black, so the new ones are black and grey alcantara…
