It's from a Quattroworld forum member who just had a batch made. I see what you mean and thanks for the side by side pics to compare. (I couldn't even figure out how to post mine properly lol...) I will go ahead and get a proper measuring tool to confirm the block measurements and see if they match what the member intended. There are also specs available online, I can't remember where- maybe here. |
I think the whole point is that the bulkhead the master cylinder is mounted on is not solid enough and moves anyway!
![]() If MJ spots this she'll no doubt give exact measurements for the one we have in the UK that works EXTREMELY well. ![]() ![]() ![]()
![]() I just installed it. Bolts didn't seem to need too much tightening to get everything flush. Would still be curious to see dimensions on MJ's version, though I think I also read it might be a slightly different fit RHD vs LHD. I seem to be the only one so far here on this batch who had to squeeze mine in a bit so maybe it was just my car. |
Move the bracket - they are all slightly different since the factory didn't care about the alignment of the strut brace so some are too tight, some too lose, some just right. I set the bracket so it gives about 1mm of preload when tightening the brace bar.
Thanks MJ!
https://forums.quattroworld.com/a8/msgs/5713.phtml Also, found this from MJ on a prior brake block group by thread here: "The block slots over the brace and has a slight preload once tightened up." So I will probably just try and tighten it carefully and see if that does it. |
