Yes, just some plain steel cut to 2m lengths by the blacksmith. I might give them a paint when I stop using them this time though!
And that is exactly where I got the lift from – they were very helpful. I went for the 2.5 ton model, which more than covers the S8 (though they did mention that they are rated conservatively). The only lift (of this type) I found that fitted the S8 was the BL-6000XLT Quick Jack, but this was quite a bit more expensive, and would not have fitted between the 205’s wheels. It had a maximum lift spread of just over 1.9m, so just fits the S8 (which is just under 1.9m from outside edge-to-outside edge of the lifting points).
Audi S8 D2 2002 |
... and a quiet word to the wise. I had a tow bar fitted to my D2Q 1997. The garage in France put it up on their hoist and fitted it. Afterwards the boot lid was not such a good fit and the car didn't look quite right. We put the car on a flat concrete surface, loosened all the tow bat bolts, gave the car a jiggle and tightened the bots back up. All was well.
Thes cars, despite their strength, can flex. Cheers
D2 FL Q 2.8 V6 2002 Taxi(?) spec - no heated seats headlight washers etc. D2 PF Q 2.5 tdi LHD rear blinds and heated rear seats, Bose, 5 speed Tip, Servotronic, Pioneer AVIC 333,333 km Murdered on a P&O ferry 2012. Cat3 write off |
I wouldn't be surprised if she showed them how to replicate a factory fit of the screen plus improvements
With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
I think you meant to post this in another thread!
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
Correct, apologies
Scott, just starting looking into this again, would you be willing to share the drawing you made up so I could try to obtain similar from a local steel supplier?
Presumably you still need some kind of jacking point pad on the steels? |
I can’t find the original CAD file sadly – I might have deleted it when I did a big computer file clear out a few months ago, but I do have a copy of the pdf I sent to my engineer for his thoughts.
drawing.pdf It shows how the Kwik Lift fits under the car but comes no-where close to fitting; it then show it with the official extenders, which still don’t fit, and then with some steel beams. Note that the car need to be raised on ramps (or some such) first to fit the lift and steel under. I used these: https://www.ebay.co.uk/itm/274671536510 You must also remember to put these back under before lowering, or there is a chance the lift will not be able to re-elevate the car (I believe it needs to be able to rise a bit with no load first, which it will not be able to do if you lower it without the small ramps; indeed, it will just bottom out without the car even touching the ground). I used some thin rubber matting on the steel under the car lifting points, but nothing else, and it has been doing well, on-and-off for the last 8 months! I certainly could not have done (or at least would not want to have done) what I have been doing with jack stands… the lifts have been brilliant. I would also recommend a creeper trolly, as the lift blocks access to most of the sides and it is a very long car to crawl to the middle of! The trolly makes it a doddle and there is still loads of room to work.
Audi S8 D2 2002 |
Thank you for posting all of this! Trying to navigate my own version of this issue, hoping this solution can work for me, too, with a Quickjack here in the US. Called around a few steel suppliers local to me. None of them knew what "RHS" was, until one shop said, "You mean, 'Rectangular Tubing?' and in the brochure they sent me it's listed as "Carbon Steel Mechanical & Structural, Rectangular Tubing." Does this sound like equivalent material to what you used? They aren't listed in metric here but when I did the conversion, the closest standard sizing they have would be a 2" x 4" x 1/4" -- all just slightly larger/thicker (so, presumably, no less strong?) than the 50x100x5 dimensions you used in mm. Appreciate anyone willing to chime in with more informed perspective/experience, in case I'm missing something. Thanks! |
For reference RHS in U.K. is Rectangular Hollow Section so ‘rectangular tubing’
2021 Q7 4M, 3.0tfsi MHEV Black Edition 2002 D2 S8, Aqua Blue Pearl, original bar FE alloys and miltek 1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting…. ** FOR SALE ** 1990 2.3 20v 7a Coupe Quattro **SOLD** 1996 2.6 v6 cabriolet, Isis red metallic **SOLD** 2014 D4, FL 3.0tdi, phantom black, sport exec lwb **DEAD ![]() Had a few Audis over the years, mostly early stuff, newest was a D3 prior to my D4, nothing much kept me smitten with other marques so I floated about a bit from one thing to another until that four ring lure caught hold Last edited by monkeyboyuk; 8th June 2023 at 10:15 PM. |
