Old 2nd March 2022, 08:36 PM
scottmgibb scottmgibb is offline
Yes, just some plain steel cut to 2m lengths by the blacksmith. I might give them a paint when I stop using them this time though!
And that is exactly where I got the lift from – they were very helpful. I went for the 2.5 ton model, which more than covers the S8 (though they did mention that they are rated conservatively).
The only lift (of this type) I found that fitted the S8 was the BL-6000XLT Quick Jack, but this was quite a bit more expensive, and would not have fitted between the 205’s wheels. It had a maximum lift spread of just over 1.9m, so just fits the S8 (which is just under 1.9m from outside edge-to-outside edge of the lifting points).
Audi S8 D2 2002
Old 2nd June 2022, 12:28 PM
christhompson's Avatar
... and a quiet word to the wise. I had a tow bar fitted to my D2Q 1997. The garage in France put it up on their hoist and fitted it. Afterwards the boot lid was not such a good fit and the car didn't look quite right. We put the car on a flat concrete surface, loosened all the tow bat bolts, gave the car a jiggle and tightened the bots back up. All was well.
Thes cars, despite their strength, can flex.
Old 2nd June 2022, 08:11 PM
S81 S81 is offline
I wouldn't be surprised if she showed them how to replicate a factory fit of the screen plus improvements
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 2nd June 2022, 08:38 PM
pete-p's Avatar
pete-p pete-p is offline
I think you meant to post this in another thread!
Cars...
Old 3rd June 2022, 09:17 PM
S81 S81 is offline
Correct, apologies
Daily driver
Previously owned
Old 22nd October 2022, 02:12 PM
sarg sarg is offline
Scott, just starting looking into this again, would you be willing to share the drawing you made up so I could try to obtain similar from a local steel supplier?
Presumably you still need some kind of jacking point pad on the steels?
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 23rd October 2022, 04:16 PM
I can’t find the original CAD file sadly – I might have deleted it when I did a big computer file clear out a few months ago, but I do have a copy of the pdf I sent to my engineer for his thoughts.
drawing.pdf
It shows how the Kwik Lift fits under the car but comes no-where close to fitting; it then show it with the official extenders, which still don’t fit, and then with some steel beams. Note that the car need to be raised on ramps (or some such) first to fit the lift and steel under. I used these: https://www.ebay.co.uk/itm/274671536510
You must also remember to put these back under before lowering, or there is a chance the lift will not be able to re-elevate the car (I believe it needs to be able to rise a bit with no load first, which it will not be able to do if you lower it without the small ramps; indeed, it will just bottom out without the car even touching the ground).
I used some thin rubber matting on the steel under the car lifting points, but nothing else, and it has been doing well, on-and-off for the last 8 months! I certainly could not have done (or at least would not want to have done) what I have been doing with jack stands… the lifts have been brilliant.
I would also recommend a creeper trolly, as the lift blocks access to most of the sides and it is a very long car to crawl to the middle of! The trolly makes it a doddle and there is still loads of room to work.
Audi S8 D2 2002
Old 23rd October 2022, 04:20 PM
Incidentally, I did not draw the car – that is from a CAD file I found online :
S8.zip
Audi S8 D2 2002
Old 26th May 2023, 02:59 PM
reyxlp reyxlp is offline
Hi,
Thank you for posting all of this! Trying to navigate my own version of this issue, hoping this solution can work for me, too, with a Quickjack here in the US.
Called around a few steel suppliers local to me. None of them knew what "RHS" was, until one shop said, "You mean, 'Rectangular Tubing?' and in the brochure they sent me it's listed as "Carbon Steel Mechanical & Structural, Rectangular Tubing."
Does this sound like equivalent material to what you used?
They aren't listed in metric here but when I did the conversion, the closest standard sizing they have would be a 2" x 4" x 1/4" -- all just slightly larger/thicker (so, presumably, no less strong?) than the 50x100x5 dimensions you used in mm.
Appreciate anyone willing to chime in with more informed perspective/experience, in case I'm missing something.
Thanks!
Old 8th June 2023, 10:04 PM
monkeyboyuk monkeyboyuk is offline
Originally Posted by reyxlp View Post
Hi,
Thanks!
Should be good with what you found, sizing is similar so a# you say shouldn’t be much different in terms of strength.
For reference RHS in U.K. is Rectangular Hollow Section so ‘rectangular tubing’
2021 Q7 4M, 3.0tfsi MHEV Black Edition
1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting…. ** FOR SALE **
1990 2.3 20v 7a Coupe Quattro
**SOLD** 2014 D4, FL 3.0tdi, phantom black, sport exec lwb
