Old 8th March 2011, 08:55 PM
Originally Posted by Ska View Post
Might be way off on this one but I replaced my washer pump a while ago and pulled it apart - the sensor bit is just a float (on my PF anyway). This gets stuck with gun from the years of different washer fluids used. So a good clean may see it working properly again. That's assuming the motor housing isn't rusted to hell.
Good too see you around buddy
Old 8th March 2011, 08:58 PM
Ska's Avatar
Ska Ska is offline
Thanks Amar, I've have developed a disappearing/ reappearing habit lately This time round due to house move
Old 8th March 2011, 09:28 PM
Stick around this time, your posts are always incredibly useful and we've never had the chance to meet in the flesh yet
Old 8th March 2011, 09:34 PM
martincieslak1
Guest
Posts: n/a
My pump was dead so I replaced it with a brand new pump from Audi and since then the warning was always ON and there is really only one way the connector can go in. The warning was so annoying I ended up cutting the wire for the sensor (pump has 3 wires, 2 for the pump and one for the sensor). Cut the wire for the sensor, and the warning should go away. My car is a pre-facelift 1997, maybe facelift models are different though.
Old 9th March 2011, 06:57 AM
Ska's Avatar
Ska Ska is offline
fair do's fella, BTW mines a PFL too. Another shot in the dark but I seem to remember on another overseas forum where this sort of problem had something to do with a dry joint on the instrument cluster. Wouldn't be the first time a dry joint caused something like this - I repaired my instrument cluster which would go dead on cold mornings when you switched the lights on!
Old 10th March 2011, 04:54 PM
christhompson's Avatar
Stupid self tapping screw who does it think it is, keep dropping out like that. Although i found a lot easier with the indicator out, then it's just one STUPID screw, but you can't do that if you have one of those fancy FL.
A wise man once said "use blutack on the end of screwdriver"
But if you obtain an old large loudspeaker - broken is fine - open it up and get hold of the huge magnet and stroke a screwdriver along it a few times - hey presto screws stay on. Don't use the same screwdriver near sensitive electrics after
