2009 Audi RS 6 Saloon V10 - 420mm Ceramics, Keyless, Soft Close, Adaptive Cruise, Glass Sunroof, Blinds, Twin Pane & UV, Freeview & DAB, High Beam Assist, MTM bits, Audi Exclusive Bits, MRC, Milltek, GYEF1 ASY2's, Bluetooth streaming music to AMI mod - 753 PS/1021 NM 2016 Audi S3 Saloon, Sepang, S-Tronic - B&O, Tech Pack etc... Company Car 1995 Audi A8 4.2 V8 quattro Sport - Bose, Solar, Blinds |
Thanks Amar, I've have developed a disappearing/ reappearing habit lately This time round due to house move
My pump was dead so I replaced it with a brand new pump from Audi and since then the warning was always ON and there is really only one way the connector can go in. The warning was so annoying I ended up cutting the wire for the sensor (pump has 3 wires, 2 for the pump and one for the sensor). Cut the wire for the sensor, and the warning should go away. My car is a pre-facelift 1997, maybe facelift models are different though.
fair do's fella, BTW mines a PFL too. Another shot in the dark but I seem to remember on another overseas forum where this sort of problem had something to do with a dry joint on the instrument cluster. Wouldn't be the first time a dry joint caused something like this - I repaired my instrument cluster which would go dead on cold mornings when you switched the lights on!
D2 FL Q 2.8 V6 2002 Taxi(?) spec - no heated seats headlight washers etc. D2 PF Q 2.5 tdi LHD rear blinds and heated rear seats, Bose, 5 speed Tip, Servotronic, Pioneer AVIC 333,333 km Murdered on a P&O ferry 2012. Cat3 write off |
