Old 28th March 2011, 10:56 AM
Godders Godders is offline
Originally Posted by Glync View Post
Forgive me being thick but who/what are TPS mate?
You're not thick TPS haven't been around for a long time and I only stumbled on them by accident when I was getting a lot of VAG servicing coming my way.
TPS are Trade Parts Specialists, they are owned by the VAG group (VW, Audi etc) and general VAG genuine service parts are approx 40% off list, though I've found A8 parts, due to low volume, only get 10-15% off, plus normal parts (trim etc) only get a similar level of discount.
They usually only deal with trade sales but you can sometimes blag a cash account and get the discounts - plus if you have a local one they will deliver free
Also I have seen a few of the AMI parts listed on fleabay etc. and the final number appears to be different on a few does this make a difference as the unit looks the same and is listed as suitable for the D3 A8?
Not sure of the difference I'm only going on what I've been told by the parts guy at Chester Audi, I wouldn't want the hassle of buying something not compatible and not knowing for sure if the unit was faulty or just incompatible.
2003 D3 A8 4.2 Atlas Grey -
Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid
After: LPG, AMI with HDD
Pending: DVB-T Tuner & fixing niggles
Old 28th March 2011, 11:16 AM
The AMI has just arrived, I've just checked the contents and it seems the Audi parts guy didn't tell me I needed a media cable to go from my device (ipod / drive) to the AMI so I'll need to order one of those
I did ask if all cables including connector cables were included and he confirmed they would be so I'm a bt frustrated.
So I can't play yet, at least I can get on with updaing the MMI
Old 28th March 2011, 12:40 PM
Glync's Avatar
Glync Glync is offline
Hi Godders
Does this set up allow you to maintain the CD changer?
Look forward to hearing more mate
Glyn
ps will check out TPS
Old 30th March 2011, 10:41 AM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
Shame I didn't stumble across your earlier post-I would have told you that you were an interface lead missing
Nick, the acurate price is £243.29 (including everything to play & keep your CD player also)
I am at Audi today so will sort out payment arrangements with them.
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 30th March 2011, 10:49 AM
A8L Chick's Avatar
I've ordered my parts to do the retrofit through TPS after getting the part numbers from my friendly dealer :
The AMI kit is : 4E0 057 785 F - N/Stk A4E0 057 785 D
The cable kit is : 4F0 051 592 A - N/Stk AMICABLESET
These are not generic part numbers accross all D3 A8's/S8's. Found this out when pricing up a kit for Tonupkid
My part numbers are different on my 07 '8. So make sure if anyone orders a kit you make sure you have the right part numbers for your own chassis number.
Old 7th April 2011, 08:43 AM
OK so MMI updated, AMI fitted and I've worked out how to get an external disk drive working with the AMI (much cheaper than an iPod)
I'm in the process of doing write ups, including one on managing mp3 tags and creating playlists but can somebody help me on how to post large pdf files ?
It's easier to create them in this format than post pics and text but the upload function restricts the filesize to 19.5K, the MMI doc is 478K, so not large by any means.
Also for those who have fitted the MMI to the cubby by the side of the CD player did you find the aperture wasn't deep enough for the unit (approx 4mm too short), if so what if anything did you do to make it fit (I feel the Dremel is itching to come out of its box) ?
I believe to make it fit in the A6 the back of the glovebox has to be cut out (friend had one professionally fitted recently and that is what was done).
I'd rather not resort to this kind of thing, plus the 8 has a mounting screw for the glove box behind where the cubby lies.
There is, as far as I can establish, only one part number for the AMI so I think the cubby housing, on the AMI, is standard and there isn't a shorter one. The aperture for the AMI in the glove box is deeper on the left to the right on a RHD car. I'm just wondering if the AMI was designed for a LHD car so the deeper part of the aperture would be in the correct place for the AMI cubby as the glovebox would be a mirror image of our cars - hope this makes sense.
Old 7th April 2011, 11:26 AM
A8L Chick's Avatar
Godders, did you take the whole glove box out or just drop it down slightly?
I installed the AMI into the cubby next to the CD player and found no fitment fouling. (I dropped the glovebox down and didn't toally remove it)
However, the clips which hold it in place were rather tough, and you have to be completely sure the MOST cables are not kinked etc in any way before committing to the last "push". You do have to be quite positive, the clips are tight. This iirc is probably the last 4ish mm you are asking about.
You'll struggle getting it out again afterwards I think
Old 7th April 2011, 11:33 AM
Try using a hosting site like http://www.filefactory.com/. Then link to them from the write up. I'm wary of allowing too large file sizes as server space is limited.
Old 7th April 2011, 12:53 PM
Removed the box first but if I had to do it again I'd leave it in place, there's enough room to get the cables fed around the back
None of the cables were kinked, I took time messing about with it and took out the CD again so I could pull the cables through to stop that happening.
I did think about the 'last push' but that'll be a last resort.
From memory the depth of the cubby is around 180mm and the AMI unit is 184mm. I think my big size 12 will be brought into play
Absolutely or it'll shoot out like Arkwrights till drawer
Old 7th April 2011, 12:55 PM
Thanks for that I have done and created a new post with the link
I don't blame you trying to keep storage to a minimum
