Old 7th April 2011, 12:53 PM
Godders Godders is offline
Originally Posted by A8L Chick View Post
Godders, did you take the whole glove box out or just drop it down slightly?
Removed the box first but if I had to do it again I'd leave it in place, there's enough room to get the cables fed around the back
However, the clips which hold it in place were rather tough, and you have to be completely sure the MOST cables are not kinked etc in any way before committing to the last "push". You do have to be quite positive, the clips are tight. This iirc is probably the last 4ish mm you are asking about.
None of the cables were kinked, I took time messing about with it and took out the CD again so I could pull the cables through to stop that happening.
I did think about the 'last push' but that'll be a last resort.
From memory the depth of the cubby is around 180mm and the AMI unit is 184mm. I think my big size 12 will be brought into play
You'll struggle getting it out again afterwards I think
Absolutely or it'll shoot out like Arkwrights till drawer
2003 D3 A8 4.2 Atlas Grey -
Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid
After: LPG, AMI with HDD
Pending: DVB-T Tuner & fixing niggles
