Old 25th May 2011, 09:33 PM
frankow's Avatar
frankow frankow is offline
Had this issue in my passenger side and it turned out to be my sunroof drain which had become detatched, not the usual air con drains.
Good Luck.
Old 25th May 2011, 09:36 PM
there's a lot of water gets soaked into those mats as well... be prepared for some serious work.
Old 25th May 2011, 10:01 PM
RanjS8 RanjS8 is offline
Default sunroof drain????
didnt know the sunroof had a drain????//
where is it please????
I ve been meaning to do this job for a while now....well since i owned the car....problem is could never quite work out from the pics how to get to the cowl drains.....didnt like the idea of filling the plenum chamber with water.....is it possible to clear those drains from below with a plumber's metal spring based pipe cleaner thingy ??????
Old 25th May 2011, 10:02 PM
at least with the weather being sh*te up here we still have the heating on so have both mats steaming away on the radiators in the basement, the smell of damp foam down there is not nice, otherwise I might have been tempted to don the budgie smugglers and partake in a bit of sauna like indulgence
Old 25th May 2011, 10:07 PM
Good Luck.
thanks, dont think its the sunroof, has all the symptoms of the other drains being clogged, luckily the process is well documented, only problem is getting access to compressed air, thinking I might try some canned computer cleaner stuff and some long tubing, ahh the joys of Vorsprung Dorch Technik
Old 26th May 2011, 03:03 PM
got any mates with car-friendly sized compressors you can borrow? One of the benefits of my hobby is EVERYONE has a compressor in their garage/shed/workshop for cleaning stuff! A little far for me to drop mine off though
It is much easier with a compressor without too much grunt - too much and you risk dislodging pipes on a lot of cars.
I had dodgy sunroof drains, but a happy side effect of pressure washing my car, including a good soaking with an under chassis angled attachment , was that it seemed to unclog whatever was stopping the water getting out.
Old 26th May 2011, 04:14 PM
Dont have Adrian, going to give it a try with what I have to hand, various pumps, canned gas, even a flexi spring drain unblocker thingy, wifes tongue is usually pretty sharp too also think it was Simon here that recently had success with using water on the scuttle drains too so might try that too, if all that fails I will probably hire a compressor, main problem I have at the moment is trying to get the 90 degree angle on the copper pipe without tools or plumber skills
