Have you tried sunroof drains? the front ones are easy, the back ones I tackled from behind the trim in the boot.
Guy, stupid question, but have you tried this:
http://forums.quattroworld.com/a8/msgs/18945.phtml I had water ingress problem in passenger footwell when I've just purchased the car. It was clogged rubber drain pipe which is easily accessible from the inside of wheel arch. It can as well be gasket between electrical electrical box with all the control units and aluminium chasis of your car. Buy new gasket and change it preventively. Here is example of what I'm talking about: http://www.passatworld.com/forums/68...en-filter.html
I'd rather drive on left |
yea i did try both those ways i also used compressed air to blast the orange pipe inside the car in the trans tunnel, i have cleared the big one that had about 3 gallons of water in there that was just under the H vac blower motor in the engine bay, but i still have water in the passenger foot well and its driving me crazy now the wood under it that is a cover for the relay box is just sodden wet carpet is soaked and im fed up of drying it and then finding it the same again the following day,
i don't want it to play up with my electrics in that box |
Guy, you don't need to play up with electrics in that box, but it can be the damn gasket.
Are you driving near Reading from time to time?
i do drive by there every so often, i have spent most of the daylight hours at it today so only time will tell now if i have cured it at last, it seems that when i plugged Botang's Hole it was not the correct hole after all, so i finally tracked it down and sealed it,
it was hidden under a paper tab that looked like just part of the paint, but you could not see that in the pictures of botangs hole as he had already removed it before taking the picture, But it is sealed at last, just hope that dose the job now. just a case of drying everything out thanks for the help Sergey ![]() |
If it's a combo of the tranny tunnel and scuttle drains being blocked, you'll actually SEE the water slosh from the left side of the tranny tunnel. You can see it happen if you're taking a right hand corner.
Also, sometimes water will actually slosh out the centre consoles rear air vents and land in the rear passenger footwells. Is this your trouble? If not, it might be something else. Have you done that big old 'invisible' drain 'ole in the centre of the scuttle? |
nope only trouble was water in the passenger foot well right below where botangs hole is located, i did have the trouble of the water in the rear air vents but i solved this with an unblocking and also this http://forum.a8parts.co.uk/showthread.php?t=3192
