Old 27th March 2009, 01:06 PM
Three possible answers here,
Does the clutch engage when you switch between economy mode and normal?
Is the system pressured?
Could the pump be U/S?
VagCom can test the clutch working if you have access to it.
Quick fit do an aircon service whereby if they can't reduce the temperature by 10% or more you get it free. Give them a try first which will bowl out under pressure if it works after they have finished
