Old 15th January 2012, 07:52 AM
Stuarta Stuarta is offline
Default Finding leak in air suspension
Anyone have any advice on how to find the leak?
I'm still a newbie A8 owner and all was well until this morning when I had the dreaded flashing icons - this is what vag-com said:-
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 02313 785 00200
VCID: 2855E99BE263
3 Faults Found:
01583 - Leak in System Detected
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 3
Fault Frequency: 74
Reset counter: 55
Mileage: 60487 km
Time Indication: 0
Date: 2011.12.05
Time: 14:38:24
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 24
Reset counter: 95
Mileage: 61176 km
Time Indication: 0
Date: 2011.12.29
Time: 11:02:55
01400 - Suspension Level Control
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 55
Mileage: 61581 km
Time Indication: 0
Date: 2012.01.15
Time: 11:27:51
I tried clearing the codes but they all came back straight away.
I'm assuming that the over-temp is due to the compressor being taxed to overcome the leak - question is, how to trace the leak?
Old 15th January 2012, 08:31 AM
Possibly luck... Let it all cool down and listen at each corner to see if you hear it, otherwise it's garage time.
Old 15th January 2012, 09:13 AM
I would put some washing up liquid (or foamy car shampoo probably kinder) into warm water in a bucket and then use a beaker or such like to throw it over the pipes, dampers etc... Maybe an older household sprayer would be helpful too. If there is a leak, you should see cuckoo spit forming.
Old 15th January 2012, 10:11 AM
Seems to be sitting much lower at the front - so I'm hoping that'll narrow things down! Will try to have a look later today. Thanks.
Old 15th January 2012, 10:39 AM
Fingers crossed it's something easy and not a blown shocker (though A8parts have them in).
Old 15th January 2012, 12:14 PM
OK - had a listen and can definitely hear something at the front - will need to wait for tomorrow to jack her up and have a look. Rear sounds fine.
Incidentally, I have often noticed a hissing noise from the front when getting out of the car and assumed that it was the system venting pressure on shutdown - I assume then that it's NOT normal?
Old 15th January 2012, 01:33 PM
This is normal, it is compensating for the loss of passenger weight.
http://www.volkspage.net/technik/ssp/ssp/SSP_292.pdf
Old 15th January 2012, 01:43 PM
Yep.. the hiss when you turn off is normal...
Old 15th January 2012, 07:34 PM
Godders Godders is offline
I'm sure I read somewhere (Allroad SSP242, page 47 on - http://www.volkspage.net/technik/ssp/ssp/SSP_242.pdf) that the hiss on shutdown is to blow dried air back through the dryer (dessicant) in the compressor to 'regenerate' it.
2003 D3 A8 4.2 Atlas Grey -
Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid
After: LPG, AMI with HDD
Pending: DVB-T Tuner & fixing niggles
Old 15th January 2012, 07:45 PM
Could be... I thought it was just releasing the pressure in the system to reduce component strain.
