Old 4th June 2012, 09:09 PM
You can have a go with my Vag-Com if you need
Thanks for the offer John, I may well get back to you though i have never used the software and havent a clue how to read the results. (unless it's Janet and John style.)
Old 4th June 2012, 09:40 PM
47p2's Avatar
47p2 47p2 is offline
I can connect it up and do the scan, clear the faults and see what comes back after that. You can post the results on here and the experts will be able to advise
Nite Blue 3.0L SE Quattro
Old 5th June 2012, 06:41 AM
Thanks for the offer. I will pm you.
Old 5th June 2012, 06:32 PM
Well, John (47p2) sorted me out with a scan this morning and it looks like the advice from all above was right, It looks like an intermittent cat bank 1. Cleared the fault and it hasnt returned (yet). Some of the other faults may well be from the previous owner's (The Laird) issues with a central locking pump (I hope); a level sensor (known and awaiting a part; horn (poss batteries - mentioned in a thread on beeping from the boot area a few days back); a parking sensor (poss an old issue? - Jim replaced a faulty one).
Many thanks to all for advice and john for his time and help.
VCDS Version: Release 11.11.3
Data version: 20120401
Tuesday,05,June,2012,11:25:41:32054
Chassis Type: 4D - Audi A8 D2
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
VIN: xxxxxxxxxxxxxxxxx
Address 01: Engine Labels: 4D0-907-560-AVP.lbl
Part No: 4D0 907 559 AA
Component: 4.2L V8/5V G01 0002
Coding: 10753
Shop #: WSC 23133
VCID: 6DDBE96A278ADF1
WAUZZZ4D43N001316 AUZ7Z0A2019945
1 Fault Found:
16804 - Catalyst System; Bank 1
P0420 - 35-10 - Efficiency Below Threshold - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D57
Coding: 08397
Shop #: WSC 02313
VCID: 3163351AFB327B1
No fault code found.
Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl
Part No: 4D0 820 043 Q
Component: A8-Klimavollautomat D13
Coding: 00081
Shop #: WSC 02314
VCID: 2A512276D6E4089
Address 15: Airbags Labels: 4D0-959-655-AI8.lbl
Part No: 4D0 959 655 T
Component: Airbag Front+Kopf 5001
Coding: 01417
Shop #: WSC 02313
VCID: 438F6FD2518EF91
Address 17: Instruments Labels: 4D0-919-033-MYX.lbl
Part No: 4D0 919 931 PX
Component: KOMBI+WEGFAHRS.VDO D42
Coding: 00483
Shop #: WSC 00048
VCID: 9025109ED078D29
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D17
Coding: 15179
Shop #: WSC 00047
VCID: 42816AD64E94F09
6 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
77-00 - Internal Supply Voltage
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 4D0 035 192 M
Component: RNS 4.2 H06 BNO 0102
VCID: 2953DD7AD3E2031
Address 45: Inter. Monitor Labels: None
Part No: 4D0 951 177 B
Component: Innenraumueberw. D06
Coding: 00001
Shop #: WSC 00000
VCID: 2855D87EC8E83A9
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00001
Shop #: WSC 00000
VCID: 040DACCE14003E9
2 Faults Found:
00774 - Level Control System Sensor; Left Rear (G76)
28-10 - Short to Plus - Intermittent
00776 - Level Control System Sensor; Left Front (G78)
28-00 - Short to Plus
Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
Component: Radio BNO 0001
Coding: 00017
Shop #: WSC 02314
Address 57: TV Tuner Labels: 4D0-919-146.clb
Part No: 4D0 919 146 B
Component: TV Tuner H06 0704
Coding: 0000030
Shop #: WSC 00000 000 00000
VCID: 2855D87E98E83A9
Address 76: Park Assist Labels: 4D0-919-283.lbl
Part No: 4D0 919 283
Component: Parkingsystem A8 RDW D04
Coding: 01108
Shop #: WSC 02314
VCID: E8D5187E88687A9
1 Fault Found:
01629 - Sensor for Parking-Aid; Front Left (G255)
31-10 - Open or Short to Ground - Intermittent
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 EC
Component: AG5 01L 4.2l5V RdW 1010
Coding: 00101
Shop #: WSC 02314
VCID: 6ED9EE662A8C249
End ---------------------------------------------------------------------
Old 5th June 2012, 07:43 PM
47p2's Avatar
Glad to be able to assist
I guess you'll just have to wait and see if the light comes on again
Old 5th June 2012, 07:53 PM
That's the fun bit with these.. Waiting to see if it comes back.
The intermittent faults, I could leave too, they do crop up now and again.
I'll probably be up doing the wiring on the Laird's solar roof soon enough, so will be able to do a follow up scan if needed then.
Old 6th June 2012, 08:07 AM
That would be brilliant. I shall try and take you up on that.
