Old 5th June 2012, 10:35 AM
Well, maybe it is the controller box, not the stalk? That's the way my thinking is going now.
Just need to find a dry day to get into the box with all the ECU's....
More symptoms to support this view. On Sunday I started off on a trip (cold damp day) and it was working fine. However at one point it just disengaged, but a few seconds later I was able to re-engage it! I didn't touch the brake - honest!
Later on (after a stop) it just wasn't working at all. The stalk was "on" all the time (as it always is).
Old 5th June 2012, 11:45 AM
Well I've had the cover off the electronics box with the controllers in it. Perfectly dry inside and no signs of any ingress of anything non-human.
Cover was a bit tricky as some of the bolts were corroded into the sockets, but it's gone back on securely and still works!
There was a bit of accumulated crud down the inaccesible edge under the windscreen so I hoovered and scraped out as much of that as I could. The seals looked OK though.
However once inside I'm rather wary. The main ECU is obviously outboard with nothing under it. So I left that alone.
The gearbox ECU is inboard and held down by 2 bolts at the front edge. I undid those so I could take it out but there was only limited movement and what appeared to be a release lever for the cabling was blocked by a fuse carrier. It wasn't obvious how to get it fully out - can anyone explain in detail?
Under that there is at least one more ECU but I couldn't see any label on the visible one. Is that likely to be the Cruise Control or is there something else to get out first?.
Old 6th June 2012, 11:41 AM
The gearbox ECU is inboard .................. wasn't obvious how to get it fully out - can anyone explain in detail?
Under that ................. likely to be the Cruise Control or is there something else to get out first?.
Having looked online I can only find an illustration of a LHD system, and there the ECU's are mounted vertically so the cruise unit can be taken out easily.
There are no other units mentioned so I hope the one under the gearbox ECU is the cruise control.
Has anyone delved that far into the box who can advise? Ideally without having to unplug the other ECU's.
Old 28th June 2012, 03:47 PM
Well, as noted in another thread I obtained a replacement Cruise ECU and had it fitted by my local VAG independent (while in there for a gearbox fluid & filter change) and it now all works fine.
Apparently all the ECU's had to come out to get at it, it's right at the bottom, so I'm glad I left it to them.
Old 28th June 2012, 04:17 PM
B@fink B@fink is offline
Nice one, it's very satisfying having the cruise back on song! My spanner waver did say it was a pain to swap mine out because of the stuff that needed to be removed.....
Old 28th June 2012, 04:20 PM
My "spanner waver" charged me £56 (inc VAT) labour to fit and test mine. Not bad really.
