Well I've had the cover off the electronics box with the controllers in it. Perfectly dry inside and no signs of any ingress of anything non-human.
Cover was a bit tricky as some of the bolts were corroded into the sockets, but it's gone back on securely and still works! There was a bit of accumulated crud down the inaccesible edge under the windscreen so I hoovered and scraped out as much of that as I could. The seals looked OK though. However once inside I'm rather wary. The main ECU is obviously outboard with nothing under it. So I left that alone. The gearbox ECU is inboard and held down by 2 bolts at the front edge. I undid those so I could take it out but there was only limited movement and what appeared to be a release lever for the cabling was blocked by a fuse carrier. It wasn't obvious how to get it fully out - can anyone explain in detail? Under that there is at least one more ECU but I couldn't see any label on the visible one. Is that likely to be the Cruise Control or is there something else to get out first?.
![]() There are no other units mentioned so I hope the one under the gearbox ECU is the cruise control. Has anyone delved that far into the box who can advise? Ideally without having to unplug the other ECU's.
Well, as noted in another thread I obtained a replacement Cruise ECU and had it fitted by my local VAG independent (while in there for a gearbox fluid & filter change) and it now all works fine.
![]() Apparently all the ECU's had to come out to get at it, it's right at the bottom, so I'm glad I left it to them.
Nice one, it's very satisfying having the cruise back on song! My spanner waver did say it was a pain to swap mine out because of the stuff that needed to be removed.....
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound. ![]() Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting. Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids ![]() |
My "spanner waver" charged me £56 (inc VAT) labour to fit and test mine. Not bad really.
