Old 24th June 2012, 05:37 AM
RanjS8 RanjS8 is offline
Default Driving issues
If footwell is wet then definitely blocked scuttle drains...furthermore relays and electrical bit all in passenger under carpet so will be effected.....I would check if te battery is charging when engine started cos if lights are flickering then could be failing alternator....
Hence I would check for water aroun te ecu area/ dry out passenger footwell and then check alternator is charging battery...then u should find your problem...
