Old 5th August 2012, 05:51 PM
RallyQuattro RallyQuattro is offline
Default 295/670-18 on D2 ? for racing !
I'm going to race with my S8-97 on some trackdays and i have found cheap Kumho slicks but they are 295 wide !!
Will that work ?
And where can i find cheap 18" rims that are 10-11" wide?
Owns at the moment:
S8-97 biturbo = RS8 My new trackday car
A8-94, A8-96, A6 1.8tq -2004
2 Urquattro 20v-90 one red, one blue,
and one old Urquattro ex rallycar,
and some other cars..
Old 5th August 2012, 08:54 PM
thebluewhale's Avatar
Don't know about the tyres but if you're fitting RS6 front brakes 18in wheels will not fit
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 6th August 2012, 11:42 AM
Why not?
The RS6 disc is only 365mm so it would fit under 18" rims.
Owns at the moment:
Old 6th August 2012, 12:00 PM
Pre facelift S8 running RS6 brake calipers. I confess, I dont recall if the discs were the standard RS6 ones, or B7 RS4 ones... Or if the rears on this car wre B7 RS4... I know B7 came into the setup somewhere , and that sadly is the level of detail I have on these photos from a car that was dismantled 3 years ago......
The wheels are standard facelift 18" avus....
ID:	4158   Click image for larger version
Old 6th August 2012, 12:40 PM
Brave man there using the 'Audi jack of death!'
Old 6th August 2012, 12:41 PM
Even braver . . . posting a pic of a car THAT dirty on here!
Old 6th August 2012, 12:54 PM
You should post this pictures and info in this thread:
http://forum.a8parts.co.uk/showthread.php?t=1047&page=4
(Your Bake Pad, Disk, Caliper Recommendations (Fronts)
Owns at the moment:
Old 6th August 2012, 01:18 PM
I could have cropped that out, but thought I'd leave it in to see how long it took for someone to mention it
Old 6th August 2012, 07:51 PM
Why not?
Erm...Thanks for pointing that out. Is there a prize for the most wrong answers on a forum?
Now to back peddle and try and recover a bit of cred (I'm praying this is right )
You can fit up to 390mm front discs on the D2 and these will not fit under 18in rims.
Ian, I bought the rear brakes from that car . I'll get the part numbers for our friend Rallyquattro the next time it's on a ramp.
There is a thread about the brake upgrade for that car on Tyresmoke somewhere which details what has been fitted.
