Old 18th September 2012, 08:29 AM
Photos of the carpeted spare wheel well please!
Old 18th September 2012, 09:04 AM
He'll be wanting a little cushion to rest it's head on next!!
Old 24th September 2012, 02:11 PM
david@a8parts david@a8parts is offline
Director at A8 Parts
Heres the carpeted well, complete with almost clean spare wheel
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 24th September 2012, 02:33 PM
The exhaust arrived Thursday, the gaskets on Friday and I got around to fitting it on Sunday. Once that was in place in topped up the gearbox, went through the proceedure with the gearstick in each position, checked the level again and then did the final check and put the plug back in when it was at about 40 degrees. Since then I have driven it about 30 miles and it really does feel smoother and gearchanges are imperceptible - except for a slight change in the burble from the exhaust you can really not tell its changed gear, so I am over the moon with it! Whether the blue fluid is really any better than the regular stuff I dont know, but it seems to be the standard fluid for any of the big engined or high performance Auto's (S4's S6's etc) so I guess there is some merit in it somewhere...
Whilst tinkering on Sunday I also got around to fitting DAB. The hardest part was finding a space to cram it in around all the rear entertainment stuff! Other than that it was an easy retro-fit - change the aerial adapter thingy at the top of the rear screen and run the new aerial cable into the boot, add in another connector on the fibre loop and tap into 3 little wires (before anyone comments (IT) I did use Scotch grips and they do look unsightly, but no-one will see them - I dont trust myself with soldering equipment)
Once plugged in it worked instantly, with no diagnostics necesary - I did go in and add it to the installed list but it didnt appear as though that was necesary - it made me feel better though having another tick in a box! It works brilliantly and hasnt yet hesitated or cut out or done anything un-toward.
Yes, the sills are still pending.....
ID:	4841   Click image for larger version
ID:	4842   Click image for larger version
At Work to Break:
2001 A2 1.4 TDi
At Work to Drive:
At Work to Hire:
Old 26th September 2012, 08:25 PM
Nice. Just need to pop a bit of B&O in there now.....
.......See, I didnt even mention the scotch grips
Old 4th October 2012, 12:54 PM
Yes, after a brief (yet somewhat expensive) 'pootle' around the local back roads at lunchtime, I'd concur its probably the smoothest box I've ever driven in any 8......
If only the comfortable ventilated massaged ride with uber-click gear changes wasn't made overly stressful by its blatant love of flashing up single digits on the MPG readout....
Old 23rd October 2012, 05:39 AM
I have just ordered spark plugs and will be doing them later today. Any chance you can list the part numbers for every thing you ordered there please so i can go and do the same to my car im willing to bet my gear box fluid has never been changed. Unlike my d2 wich had a change and new filter every 20k miles. Im also going to do an oil and filter change. Would also like some infor on fuel filter ? And its location to change ect
Thanks david
Old 23rd October 2012, 07:28 AM
OK, so my shopping list went like this:
W12 Specific Parts:
12x Spark Plugs Part No 101905600A
1x Oil Filter 07C115562E
1x Sump Plug N90813202
2x Air Filters 4E0129620D
10 Litres ATF Oil G055162A2
Gearbox Filter 09E325429
Gearbox Gasket 09E321371
D3 Generic:
1x Fuel Filter 1J0201511A
1x Pollen Filter 4E0819439A
To Change the spark plugs you need to remove the upper section of the inlet manifold (as per photos) and as such the correct proceedure is to replace the gasket when you refit it. I didnt bother with this because my gaskets looked fine (they are actually part metal so quite robust) and they cost around £70 each.
Check the back of your service book for the recall stamps and see if there is mention of the coil pack recall - its sure to have been done by now on your car, it was quite a few years ago. If you cant do that call any Audi garage and they chould be able to check if there are any outstanding recalls on your car. The updated part number is 07C905715A so if all else fails have a look at them when you get the manifold off.
Fuel filter is located just in front of the offside rear wheel. There is a small section of undertray which you will need to remove to gain access to it. The fuel lines are connected via two plastic clip on fittings so you just have to depress the white plastic clip (you fat bitch ) and the fitting will slide off the filter. BEWARE the fuel will be under pressure so get ready for a petrol shower, or at least have some rags handy. After that its one bolt that holds the filter in a plastic cradle, remove refit and job done.
At Work to Break:
2001 A2 1.4 TDi
At Work to Drive:
At Work to Hire:
