Old 1st October 2012, 07:52 AM
Anyone know of a good Glasgow engineering shop that might do this?
So, any thoughts on where I might get the hole in the chrome lock surround enlarged a little (see last photo in earlier post)?
Old 1st October 2012, 08:22 AM
47p2's Avatar
47p2 47p2 is offline
Buy a Dremel and have the butler ream it out for you
Nite Blue 3.0L SE Quattro
Old 1st October 2012, 05:40 PM
Ooooooooh Matronnnnn
Old 1st October 2012, 06:59 PM
I just knew someone would pick up on this!
But, back to to the boot lock - does anyone have a 'plumbing' diagram for the central locking to help me work out where the pipes go and what's missing?
47p2's Avatar
The gentry are like that, inbreeding and all that stuff
Old 1st October 2012, 07:04 PM
Will this do?
Old 2nd October 2012, 05:13 AM
Brilliant! Thanks.
Old 2nd October 2012, 06:16 AM
sloss's Avatar
sloss sloss is offline
So that looks like one pipe goes into the bootlid. As stated mine was nipped at the hairpin bend in that diagram and was leaking a bit.
I joined it using a straight connector from a windscreen wash system I'd hoarded away for just such a use.....
Old 2nd October 2012, 07:18 AM
Looks like another hunt is required. If you recall, in my car, the pipe from the actuator on the boot lid goes into the boot and then disappears into a wiring loom at the back of the central locking pump. This must be the pipe in the diagram that goes through the grommets at 17 and 17a.
BUT, this isn't the pipe that has the cable ties on the end.
So, my guess is that the pipe has been cut somewhere between 17a and the junction with pipe 15, so all I need to do is find the other cut end to the pipe. I wonder if this cut end is just tucked into the loom?
Does that make sense?
Old 2nd October 2012, 08:03 AM
Will this do?
Intriguing that the nearside front door and offside fuel flap are on one connector and everything else on the other.
Where is the actual pump, I've never seen it?
