Old 1st October 2012, 07:04 PM
I just knew someone would pick up on this!
But, back to to the boot lock - does anyone have a 'plumbing' diagram for the central locking to help me work out where the pipes go and what's missing?
Will this do?
Old 2nd October 2012, 05:13 AM
Brilliant! Thanks.
Old 2nd October 2012, 06:16 AM
sloss's Avatar
sloss sloss is offline
So that looks like one pipe goes into the bootlid. As stated mine was nipped at the hairpin bend in that diagram and was leaking a bit.
I joined it using a straight connector from a windscreen wash system I'd hoarded away for just such a use.....
Old 2nd October 2012, 07:18 AM
Looks like another hunt is required. If you recall, in my car, the pipe from the actuator on the boot lid goes into the boot and then disappears into a wiring loom at the back of the central locking pump. This must be the pipe in the diagram that goes through the grommets at 17 and 17a.
BUT, this isn't the pipe that has the cable ties on the end.
So, my guess is that the pipe has been cut somewhere between 17a and the junction with pipe 15, so all I need to do is find the other cut end to the pipe. I wonder if this cut end is just tucked into the loom?
Does that make sense?
Old 2nd October 2012, 08:03 AM
Will this do?
Intriguing that the nearside front door and offside fuel flap are on one connector and everything else on the other.
Where is the actual pump, I've never seen it?
Old 2nd October 2012, 09:05 AM
The pump is behind the side panel that is behind the CD changer. You'll see it if you ever need to get at the aerial
Old 2nd October 2012, 09:41 AM
Given the location, and the plumbing diagram, this suggests that 2 separate pipes (boot lock and fuel flap) will be traversing the boot space somewhere, ending up in the same area around the fuses. Odd really, presumably they're behind the trim on the boot sill.
(rather different to my earlier assumption )
Old 2nd October 2012, 09:54 AM
99% sure they go forwards from the CLP over the wheel arch, splitting for nearside doors, then across the back seat floor towards the drivers side, splitting as required to go into the offside doors and two feeds to come back over the offside rear wheel arch to head to the boot and fuel flap...
The reat seat squab is 2 cross head screws and 5 mins to remove to check....
Old 2nd October 2012, 09:59 AM
They do mostly, indeed go forwards but the boot lock pipe goes forwards and through the grommets by the nearside hinge and into the boot
Old 2nd October 2012, 10:02 AM
So that diagram is probably for a LHD model - fuel filler still on the right?
It will presumably still need 2 pipes into the offside rear area.
I disabled the secure unlocking on mine as it's rarely driven alone and is a PITA otherwise. (Though it's enabled on the Focus - different pattern of use)
Edit: beaten to it by others.
