Old 3rd October 2012, 10:44 AM
I'll open it up soon to see if that gives any clues.
Well this is what's inside. The reverse of the PCB is almost unused, just a handful of short tracks typically routing a group of (presumably) TV-related signals across something else.
The bottom left connector is the 4 TV aerials. Bottom right has TV on the left and radio on the right (my guess).
I'm also guessing that the chips are monitoring the TV signals and controlling some switches, you can see the 4 tracks converging into 1 in stages.
Couple of coils too, presumably for frequency filtering?
This "supports" my theory that this particular unit is an active diversity monitor switcher taking tv/radio input from 4 aerials and producing a single TV and single radio output.
But that makes no sense married with my 4-input TV tuner.
Not clear where the power for the chips comes from, or what voltage it would be.
Old 3rd October 2012, 12:35 PM
So I just did a little test and removed the "spiral" whip aerial on the nearside rear which I know is for the phone - and radio reception also faded out.
So I'm coming to the conclusion that "whatever" TV aerials I have are quite possibly directly connected to the tuner.
What's more I've already measured a 10V output on the tuners aerial sockets so they "may" be powered/amplified.
All of which leads me to wonder if I can actually use the diversity box to feed my new DVB-T tuner. It will need some power to run it though, maybe I can put that in through the radio aerial lead that I don't need?
I feel some bench-testing coming on.
Unless someone here knows the answer?
