Old 10th October 2012, 11:01 PM
From memory it's about 1l per 1000m (or 1000km) is the 'allowed' figure for the ABZ I had.
Old 11th October 2012, 07:41 AM
sundayrider sundayrider is offline
I know they all vary but my 4.2 uses a drop and says in the manual it will but for the life of me can't remember what it is, (up to 1l per 100km is what i've got in my head) but I don’t ever remember getting a warning on the DIS, even when it’s been low. But low for me is at the bottom of the dip i know there's still plenty in them, I top up fairly regularly and check weekly but never kept a record of it to miles covered.
And the car is an early PF.
Have you got access to vagcom?
Sorry no access to vagcom.
Old 11th October 2012, 01:18 PM
It's 1l/1000km(600mi). I think there is no level sensor on PF, just pressure sensor and FL have combined level/temperature sensor as well.
Old 11th October 2012, 02:11 PM
Well the local Audi specialist can't get me in until next Friday. I've flushed and changed oil & filter, couldn't get to the oil pressure switch will need ramps.
Test drove the car and the light came back on, gutted.
I am now hearing noises, probably in my head but think it's a job for the garage.
Old 11th October 2012, 05:46 PM
sloss's Avatar
sloss sloss is offline
Do not run the engine until pressure is checked!
Old 11th October 2012, 05:50 PM
yeah I would agree, sounds like it could be the oil pump maybe
Old 24th October 2012, 04:55 PM
Just a quick update, the garage checked the oil pressure and said it was okay. Fitted my oil pressure switch and said that sorted it.
Unfortunately the light and warning chimes continue, looks like it will be going back
Old 24th October 2012, 05:11 PM
47p2's Avatar
47p2 47p2 is offline
Could be a broken wire
Nite Blue 3.0L SE Quattro
Old 28th October 2012, 09:41 PM
Car booked back in for next Friday. Looking at when the light comes on, it's always at 1500 rpm and usually when the revs drop down as the gearbox changes up.
Are there different sensors for different engine speeds or any other explanation?
