Old 30th January 2009, 08:54 AM
harpersimon
Guest
Posts: n/a
Er.. I did - and I don't see anything that says Gaiter replacement ?-Plenty of stuff about drive shafts and axles but can't see where it tells you how to remove the gaiter when one is split - assuming its part of taking the drive shaft out but don't see that comprehensively described either!?
** Update** - Found a CV replacement post by using the groovy Google search - which took me here
Technically this post is in the wrong section - should be moved to Axles and Steering with the other CV stuff?
