Old 17th July 2013, 03:32 PM
Keep the old jack David and i'll make up a "man's" jack with the parts and you can have that.
Have you got any breeze blocks or hard wood blocks lying around?
I use a trolly jack at home, that'll get the car high enough for support under.
Old 17th July 2013, 04:20 PM
Thats a kind offer mate.
Plenty of wood though - that's how I managed to lever the car up enough to get the trolley jack in!
A trolley jack was on my tools wish list. Its now at the top. SWMBO also said I can have a garage with a flat floor and a pit! Not sure that'll I'll swing a two poster lift though!
Old 17th July 2013, 04:21 PM
Though..On a related 'jack of death' story.. the Mk1 Mondeo had a similar jack, and if I hadn't been wearing a chunky wedding ring, I'd have had a fairly messed up hand when it fell backwards off the jack while I was putting the new wheel on. Trapping my fingers between the tyre and the arch, managed to slide the fingers out to see the car sitting with the ring between the arch and tyre, even managed to get the ring back in one piece when the RAC guy finally turned up.
So marriage isn't that bad after all lol.
Old 17th July 2013, 04:51 PM
I also have a spare jack similar to the one Dezzy used to bolt the head off the A8 jack to, so if' you'd rather have one like that, David, you're welcome to it - I almost threw it out in the great garage clear out!
Old 18th July 2013, 06:42 AM
Hey just looking at your photo's there David and that jack that folded on you is different than mine, are the jacking points different on the FL than PF or that jack you have is from an A4. The jacking point has some steel in it and the locator on the jack has a magnet so it's easier to keep it in the jacking point. Not that it makes much difference as the 8 ones fold aswell, but i don't think that's the jack for the car.
The reason i used the SAAB jack was the 9000 is similar in weight to the 8 and it has a flat surface on top for bolting your locator to, i did have another but i think it came from an Astra so didn't thnk it would be up to it. Just be careful brothers, don't make the same mistake Audi did.
Had a quick look on ebay and there are a couple of 9000 jacks for sale, also scissor type jacks with a 1.5 ton rating but same problem with modifing it to suit the cars jacking point.
ID:	6402   Click image for larger version
Old 18th July 2013, 07:42 AM
I think that the body is the same but I can see that the "groove" which positions on the jacking point is continuous on mine but shorter on your jack. The jack is (was!) rated at 1000kg. Jim has kindly let me have his old jack as he has the up-rated version which looks more substantial.
Old 18th July 2013, 07:54 AM
Thats what made me think that jack was not for the 8, the 8 jack dosent have a groove it actually protrudes out and sits inside the cup on the underside of the car, the part that is gray and looks like a groove is the magnet.
You can get bags that fill from the exhaust, they were used a lot by off roaders for recovery and on soft ground where you would just jack a jack into the ground. I thought about putting one in the boot of the 8 but wasn't sure how soft the underside of the cars is.
Old 18th July 2013, 08:00 AM
David, are our/your 2 jacks identical? If so, it's highly unlikely that we both had the wrong jack isn't it?
Old 18th July 2013, 08:19 AM
My late FL jack looks (if my memory is working) very much the same as my PF one, and I wouldn't ever use either!
Part number stamped on it is 8D0 011 031C, which may actually be from an A4?
No magnet, just a big nylon lug with a groove in. Rated 1000kg as usual.
Old 18th July 2013, 08:14 AM
The jack I got from Jim is exactly the same as mine (with the groove in the top) and the part number is the same - 4DO 011 031D. It also conforms to the pictures in the handbook. With the FL the jacking point is a ridge on the sill adjacent to the jacking pad point used by 2-poster lift arms. The handbook identifies these both quite clearly labelling the pad as "Jacking Point for Workshop Lifting Platform" and stating that the vehicle jack should not be applied here. So it would appear that there is a difference in jacks and jacking points between PF/FL.
