Old 21st August 2013, 04:26 PM
roberto's Avatar
roberto roberto is offline
Default AMI bits wanted for D3 S8
i have 2 6 stack cd players , i want to install AMI what do i need and how do i do it ??
thanks in advance
Old 21st August 2013, 04:32 PM
you need to swap one of the 6 stacks for the AMI unit, unplug one, plug in the new one and its done, should be no need to recode
Old 21st August 2013, 04:34 PM
roberto's Avatar
Default wow !
great stuff any idea what i have to buy ?
Old 21st August 2013, 04:42 PM
oh sorry looks like you needed more - you need the AMI unit and the small lead that connects the unit to whatever method you want to use to play songs
you will not need any bridge adapters as you already have 2 cds
choices for the lead are
IPOD - that gives you the usual functionality through the MMI
Mini USB - lets you connect a harddisk, also works through the mmi
Std USB - also as above
standard little connector (like headphone jack) plug in any device using the headphone socket - but no mmi control
i went for the 250gb harddisk (you will find some audi ones on ebay) however 250gb of music is insane, i would probably have been fine with a 32gb pen drive
i also have the ipod adapter but only used it once
thats all you need really
there are loads of threads giving the part numbers on the forum.
Old 21st August 2013, 04:54 PM
roberto's Avatar
is it this part number anybody
8p0 035 785
Old 21st August 2013, 05:05 PM
will check that one
in the meantime check these
http://www.audi-resource.com/amiinstall.php
Old 21st August 2013, 07:02 PM
roberto's Avatar
thats usefull but which bits of that list do i need ?
ive got the cable and the hard-drive
Old 21st August 2013, 07:46 PM
if you have the cable (its not a normal usb cable) then just this bit
Audi AMI Interface (4E0 057 785F) Alt (8T0 035 785 A)
Old 22nd August 2013, 02:08 AM
roberto's Avatar
http://www.ebay.co.uk/itm/1908797815...84.m1438.l2649
the part numbers on this are very similar will this be ok ?
this item part number is 8T0 057 785
you say this number (4E0 057 785F) Alt (8T0 035 785 A)
do the 4EO and 8TO make any difference ?
Old 22nd August 2013, 05:11 AM
no , it looks the same but that ones not for you
