Old 20th June 2014, 08:25 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Ignition Feed
Does anyone know if there is a ignition feed in the around the head control unit that's safe for powering a dash cam?
I'm thinking of the sunroof motors.
[center]
06 3.0TDI Quattro:
Options:
Old 20th June 2014, 08:31 AM
I don't know how the D3 is wired but I used the sunroof power to run an auto-dimming interior mirror on my old (PF) D2.
It was just a matter of rummaging around with a multimeter to identify a suitable supply that wasn't always live. In the end I found a very convenient one that appeared to be permanent but actually only stayed live for a minute or two after turning the ignition off, presumably to allow for closing afterwards or on the remote.
I'd guess the D3 is similar, so worth testing.
Old 20th June 2014, 08:44 AM
ScottD3's Avatar
That would be a good one.
I don't mind routing around but there is so many plugs and cables up round there.
[center]
06 3.0TDI Quattro:
Options:
Old 27th June 2014, 05:42 PM
ScottD3's Avatar
I found an ignition feed.
3rd pin in on the picture.
Does anyone know what this plug is for?
Name:	2014-06-27 16.06.49.jpg
[center]
06 3.0TDI Quattro:
Options:
Old 27th June 2014, 05:59 PM
ScottD3's Avatar
Think I found it.
http://www.audi-portal.com/en/diagno...ors_17288.html
3. Connector - light sensor -G399
[center]
06 3.0TDI Quattro:
Options:
Old 27th June 2014, 08:58 PM
I used that for mine (seemed to be the only one in there that was 12v IGN) but had to solder my ground to the contact for the bulb as I just couldn't get an earth from a wire and got fed up.
Old 27th June 2014, 09:26 PM
ScottD3's Avatar
Cool.
You don't happen to know a part number for the plug?
I'll sit down on ETKA tomorrow to try and find it.
[center]
06 3.0TDI Quattro:
Options:
Old 8th July 2014, 07:11 AM
ScottD3's Avatar
Its all installed and working fine.
I used this little port off the heads up controls.
Used the proper Audi Plug and cables, then connected them to a random mobile phone charging cable I had which fitted the Camera.
Put it all back together and it ended up like this.
All in and working.
[center]
06 3.0TDI Quattro:
Options:
Old 8th July 2014, 07:28 AM
That's one tidy install Scott, what did the port you used do or is for?
Old 8th July 2014, 08:04 AM
ScottD3's Avatar
Its listed as some light sensor.
It has a 12v ignition feed, earth and 2 more pins, which I assume are canbus.
[center]
06 3.0TDI Quattro:
Options:
