Old 6th September 2014, 05:45 PM
Jimbo's Avatar
Jimbo Jimbo is offline
If there are no symptoms aside from the box being in limp mode (which basically gives you 3rd gear and reverse!) once you're on open roads and don't need to go between P R and D, try pulling over and turning off, then restarting with it in N. If it will then drive normally then your most likely cause is the range select switch aka F125.
As above VCDS will show this as a stored fault if that's the reason.
Don't drive it far in limp mode as it puts extra strain on the box.
Thanks guys,
i also thought it was in limp mode but all gears engage in drive. It drives normaly still shifting smoothly enough through all gears!
I have a scan tool coming in the post so i will see how i get on with that.
Thanks for the info and i will do some reasearch on the f125.
If i was to dissconnect the battery for 15mins would this reset the fault as its not in limp mode as such as all gears work?
Thanks again
James
