Old 4th October 2014, 08:21 PM
Mickleson Mickleson is offline
Default Sticky auto
Hi James,
My A8 Quatro Sports has the same problem all lights on the indicator red, I did exactly as suggested and it drove ok but it's gone again, where did you got the fault finder from, did you find out what the fault code was?
Mickleson
Old 5th October 2014, 09:35 PM
Jimbo's Avatar
Jimbo Jimbo is offline
Originally Posted by Mickleson View Post
Hi James,
Mickleson
Hi
I cant remember what the actual code number was, but it was for the range control position switch, once cleared it has not returned.
I only ordered a cheap vag code reader for £18 i think off ebay, just to see if the fault would come back then if it did i would shell out for the real vag com.
How did you get the fault cleared if you have no code reader?
James
Old 11th October 2014, 12:05 PM
Hi jimbo,
All I did was as suggested by a member on the forum, just stopped turned off the ignition even withdrew the key just in case! Stared up as normal and the fault was gone, and so far not reappeared, we can only hope...
Mickleson
