Old 15th September 2014, 10:09 AM
andycaca andycaca is offline
Default RNS-D change GPS antenna but still no satellites
hello people
i've just changed the boot mounted GPS receiver with one that i bought from A8 parts. unfortunately it doesnt work, the head unit is still showing 0 satellites located out of 30.
i have made the connection in the boot lid, and also pulled out the head unit slightly and checked the connection there.
am i missing something? this is all assuming the GPS receiver is working
thanks
andy
Old 15th September 2014, 10:22 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Have you tried plugging the aerial in directly into the unit?
There could breaks or something in the cable.
[center]
06 3.0TDI Quattro:
Options:
Old 15th September 2014, 10:30 AM
also how long have you given it and did you drive around to give the unit time to locate satellites?
Old 15th September 2014, 10:57 AM
thanks for the quick replies
i cant plug the receiver directly into the head unit, the connectors are different and i dont have a spare cable to butcher
are there any joins in the cable aside from where it connects to the head unit and receiver?
i left the satnav turned on for a good 5 minutes whilst i did other stuff as i have read previously about it taking a while to get the first fix. the car is outside with a clear view of the sky...
confused!
Old 15th September 2014, 11:01 AM
ScottD3's Avatar
I might have a good spare length somewhere if you want to use it as a tester or even a generic aerial that fits the RNS units if you want to use them as a test and if I can find them.
[center]
06 3.0TDI Quattro:
Options:
Old 15th September 2014, 01:37 PM
You can get a cheap hockey puck style one from ebay for less than a tenner, plug this into the headunit to test. If this works then you can mount this in the void between the top of the instrument cluster under the dash.
Old 15th September 2014, 02:17 PM
I'd give it a bit more than 5 minutes if it's not had any satellites for a while..
Old 15th September 2014, 02:36 PM
I remember after the aerial failed on my old S8 (RNS-C admittedly) it took ages after the aerial replacement to find them again.
Greg66 Greg66 is offline
Yep: my very first post here explains this option (http://forum.a8parts.co.uk/showthrea...1510#post21510)
IIRC when I changed mine it picked up the new satellites very quickly - 30 seconds to a minute, I think.
Old 15th September 2014, 04:27 PM
I've done some further reading and am now sat in the car. I'll give it till 6pm...
