Old 12th December 2014, 12:02 PM
Thanks Ainars
Old 12th December 2014, 04:55 PM
mik15 mik15 is offline
i bought my set from blauparts.com, got the basic one for $200(i think i got it on sale or something as i checked later and it was $235 or so) and water pump and T-stat from europaparts.com.
The timing kit is all INNA and the water pump is Hepu with metal impeller($cca 90). The T-stat is OEM(cheap anyway), 82C for hot climate country. Overall super-happy with the prices. I didn't go for the other ones on blauparts as i don't need their DIY's nor the coolant.
Old 15th December 2014, 12:33 PM
Belt 078 109 119 J £81.32
Idler pulleys x2 077 109 244 C £95.99 each
Idler Pulley 077 109 244 E £76.14
Damper up to chassis no 4D-Y-016 500, 059 109 479 B £147.77 from chassis no 4D-Y-016 501, 077 109 479 D £147.77
Water pump with seal 077 121 004 PX £113.11
Thermostat 077 121 113 D £26.27
O-ring for thermostat N 901 368 02 £4.90
Audi also say camshaft sprocket bolts need to be replaced x2 N 906 371 01 £4.86 each
Is the damper the tensioner?
And what about rollers and guides?
And are these prices plus VAT or VAT included?
Old 15th December 2014, 01:43 PM
All prices including VAT.
As far as the rollers and guides go it's just the matter what they are called, Audi calls them idler pulleys.
Looks like I missed tensioner as the Audi has called it clamping lever, 2 versions depending on chassis number, See attached pdfs for more details. E has been superseded by F, price is £177-178 for all versions.
Old 15th December 2014, 01:50 PM
And 2 more pdf's with different view from ElsaWin
Old 15th December 2014, 02:08 PM
Thanks again!
I make that over £800 just for parts!
Old 15th December 2014, 02:24 PM
Unfortunately it can get expensive if you use genuine parts, change the lot and have somebody else do the job.
I did my PF on budget, first time belt only, about £30, second time belt £30 and damper about £60 from Germany + opened up rollers, cleaned old grease out and packed with new grease.
Old 15th December 2014, 05:08 PM
Pretty sure I was the thick end of a grand for a service and timing belt at a4audi with water pump, etc.
Old 15th December 2014, 08:05 PM
Inchcape Audi Swindon Quoted me £884 last year for mine including pats which I thought was pretty ok for the whole shebang, so it wouldn't surprise me if the parts came to about £600 or more. The fact that they did it for £100 incl vat was a bonus in the end
Old 1st January 2015, 07:47 PM
mark_le_b mark_le_b is offline
Audi dealer in Jersey quotes near on £1100
