I was assuming you were referring to a separate relay, but yes, thinking about it the relay is probably an integral part of the module and, while possible, it's probably unlikely to be a fault with the module if you've changed it.
I haven't checked the wiring diagram, but I suspect that, if you can identify which connections go to the mirror motors, you could unplug the module and activate the mirrors manually, using a link wire or 'Power Probe' to determine if the fault is post or pre module.
