Old 31st May 2015, 10:23 PM
When the pumps 'fail' as they do, they still prime, but don't deliver the required pressure, so the engine is starved.
It wouldn't account for any of the electrical gremlins you are seeing, and the chances of pump and electrical issue at the same time is virtually nil.
I'd definitely be checking the connecting blocks for bad earth / positive connections as previously suggested. Even if they look good, take them off, clean them up and reseat.
Failing that, I'd probably be looking for any signs of water ingress in the plastic plenum chamber under the bonnet at the back passenger side of the engine bay. It houses the gearbox and engine ECU, along with ESP/TC/ABS. Moisture in there can cause all sorts of 'fun'
