Old 8th July 2015, 07:26 AM
ahd91 ahd91 is offline
I've not checked, no. Will look at that. Thought perhaps this is a crank sensor issue - the relay won't power up if there's no signal from that will it?
The other interesting thing is that I get the PRNDS light up when the car won't start, and there's an implausible signal code. If and when the car does start, that goes away and there's no transmission problem. Could the TCU be in any way affecting the fuel relay, or is the underlying electrical issue affecting both of them?
