Old 20th August 2015, 01:41 PM
mannyo mannyo is offline
Del, I've removed the grill and have access to the adjustment screws on the radar.
There are three adjustment screws, two on the upper part and a single one in the bottom right. Which one of these three should I be tweaking?
Manny
Past
Old 20th August 2015, 01:47 PM
Top left and bottom right
ID:	11715   Click image for larger version
Matt
Old 20th August 2015, 01:54 PM
1 is Vertical
2 is Horizontal
Matt
Old 20th August 2015, 02:31 PM
Thanks for that, I've tweaked the bottom right and been out for a drive after redoing the basic settings. All angles are still showing zero, and ACC is unavailable so it must still be learning.
Manny
Past
Old 20th August 2015, 06:05 PM
Did you switch it off prior to departing for a drive, I forgot to do this once and it said unavailable until I turned it it off and went for the next drive.
Also from reading your symptoms I'm wondering if the -2.7 means the beam is pointing up at the sky, could explain why it only see trucks.
I think a clockwise turn of the lower screw should bring it down
Thanks Matt for the diagram, where dd you get it from?
Old 20th August 2015, 07:13 PM
First image is Elsa, second is from the Self Study Programme PDF.
Matt
Old 21st August 2015, 03:55 PM
After a number of drive cycles today, following the 1/4 turn clockwise on the vertical adjustment I now have the below. I know which is horizontal now, just need to work out which way to try tweaking that. Still does not pickup cars, so maybe its also pointing off left/right.
Manny
Past
Old 22nd August 2015, 11:38 AM
First of all Great write up ! And I have a question.. what are the actually operating parameters?
Is it all ment to be zero ? ...
I have the same problem on mine .. but it only started doing this since a stone hit the acc cover and broke it.. it's been replaced with a non W12 acc cover because Audi say it's part of the grill ... dose any one have the part number for the W12 ACC cover plate ...
And manny if you know what the parameters are let me know and il check mine ... I'm stuck in bed with vertigo at the moment
