Old 17th August 2015, 07:40 AM
mannyo mannyo is offline
Need to work out how to tweak mine, it only picks up large vehicles and will sometimes trip off after a period of following behind a lorry in roadworks with an ACC BLOCKED! error.
Manny
Past
Old 17th August 2015, 07:56 AM
Now you have a screen shot of yours and it's clearly out of spec I would tweak the vertical adjustment screw say 1/4 turn clockwise and then do the basic settings, make a note of the adjustment and drive for a while to see what figure changed by the adjustment carried out.
Good luck mate
Old 17th August 2015, 12:41 PM
Del,
Thanks for taking the time to write such a detailed post..... I remember the days when I had time for such fun things....
Old 17th August 2015, 02:03 PM
Your welcome Ian, now that I have finished rebuilding the house I have time for little projects like this when I'm not offshore.
I wonder if the demand for ACC parts will go up after the write up, I'll be more then happy to receive commission on each radar sold in the form of a beer at the next meet
Old 20th August 2015, 01:41 PM
Del, I've removed the grill and have access to the adjustment screws on the radar.
There are three adjustment screws, two on the upper part and a single one in the bottom right. Which one of these three should I be tweaking?
Manny
Past
Old 20th August 2015, 01:47 PM
Top left and bottom right
ID:	11715   Click image for larger version
Matt
Old 20th August 2015, 01:54 PM
1 is Vertical
2 is Horizontal
Matt
Old 20th August 2015, 02:31 PM
Thanks for that, I've tweaked the bottom right and been out for a drive after redoing the basic settings. All angles are still showing zero, and ACC is unavailable so it must still be learning.
Manny
Past
Old 20th August 2015, 06:05 PM
Did you switch it off prior to departing for a drive, I forgot to do this once and it said unavailable until I turned it it off and went for the next drive.
Also from reading your symptoms I'm wondering if the -2.7 means the beam is pointing up at the sky, could explain why it only see trucks.
I think a clockwise turn of the lower screw should bring it down
Thanks Matt for the diagram, where dd you get it from?
Old 20th August 2015, 07:13 PM
First image is Elsa, second is from the Self Study Programme PDF.
Matt
