Yep, problem solved, albeit at a £625 cost.
http://www.caraudioexpress.co.uk/pro...&cat=29&page=1 All I need additional to this is a set of 6.5 inch components and sorted. Ill try and use my 5.25 inch units initially. |
This any good to you? I found it on ebay, complete Bose D3 amp, sub, speakers. £160
http://www.ebay.co.uk/itm/291570894293
If so, I might do this instead as an interim measure. |
The Amp will need Component Protection removed so it can be used in your car. Main Dealer may do this, or a specialist with the correct software. Price is around £60~£75
Here's some info on the differences between the systems.
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 22nd October 2015 at 08:45 AM. |
Thanks. Appreciated.
Watching this with interest as mine has the standard system (ie non-Bose or B&O). I'd like to make it a touch better too. I wonder if there are better drive unit/s that can just be swapped for the original drive units? I can't be arsed messing with the amps and wiring etc, but swapping drive units out is do-able I guess.
Lee 2017 Nissan Leaf Tekna |
