I never fitted the door properly because I wanted the doors right first. as for engine never had a proper s8 to compare the drive. I thought it was ok. as for the meeting Jim I replace the exhaust as I told Ian
Things are on the up. I've done best part of a thousand, surprisingly pleasant miles in her, also squeezed in some basics:
Oil flush / oil filter / spark plugs / fuel filter / pollen filter / air filter change Balanced the wheels A/C regas New wipers Also swapped all 8 coil packs which made a huge difference to the engine wobble. Checked the timing also and its bang on, which is good. Intermittent PDC annoyance has gone away since I removed a mm of paint that was overlapping the front far right sensor. Nice easy win ![]() I've ordered (and actually received) the replacement bracket from Audi that holds the rear armrest on. I really expected that to be unavailable but was lucky ![]() Also got all the door card clips to sort the doors, but first the door glass will all be changed for twin pane heat and reflective to match the heated windscreen that will be replaced and connected shortly.... Since regassing the A/C though it has highlighted the climate is in a bit of a muddle. There's definitely at least one broken flap motor which is sending hot air where it shouldn't. Should be easy to sort once the interior is out.. Immediate job is to swap the engine ECU - The current ECU has almost certainly been fiddled with. It shows no errors. At all. Not even low oil, and many measuring blocks are absent. The remaining bit of wobble on the engine I suspect is a lambda off on one bank, but the ECU tells me nothing.... The power output is already up massively from a full service and the coil packs and its a pretty pleasant and pokey drive now. If I can get a smooth idle I'll be well chuffed. Then it'll be onto the interior sort out, which shouldn't take long really, just a strip clean and refit with couple of minor fixes.... ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
>> to match the heated windscreen that will be replaced and connected shortly.... Great idea ![]() Wanted to do that on my car since it was retrofitted with heated windscreen. Ian, do you know if heat reflective *rear* windscreen was available as well?
I'd rather drive on left |
If you have TV and heated windscreen I wonder what happens to the rear screen... Either way, if I was going to change the rear screen, I'd change it for a PF one as it is clear with no heating element lines. Its subtle, but looks much nicer imo ![]()
Shame it's been neglected. Great to see it getting the TLC it deserves. From memory, I fitted the S8 mirrors, grills, final edition wheels (I think), and detailed it. MRC changed a coil pack too, so one of them should have been newer than the rest.
Given that it was now 5 years ago, a fresh one won't hurt ![]() You can tell it was a while ago, VAT was 'only' 17.5% ![]()
Can't believe it's been that long, I thought it'd have been about three years back. Makes sense though, I've had the C6 three years, and had the C5 inbetween.
one coil pack £115 ?
tell me you are joking ...please ! |
#30
Does sound pricey - and even I can swap out a coil pack, it's probably high because I asked for a compression test and diagnosis, too. This is after Ben Williamson told me the engine was knackered, and to keep an eye out for a new one. Good job I got a second opinion.
