Old 18th November 2015, 06:22 PM
Palmer Palmer is offline
Had exactly the same problem - it's the ballast, Light unit has to come out and they're still a pig to remove!
Oh buggar!
Expensive fix?
Old 19th November 2015, 04:47 AM
IIRC I got a second hand light unit on ebay and swapped the whole unit. Try our sponsors and ebay first
Old 19th November 2015, 07:08 PM
jza8's Avatar
jza8 jza8 is offline
I had the same problem when the ballast went. Could also be the igniter behind the bulb, but the ballast is most likely. Took me an hour to swap on the passenger side, headlight didn't have to come out.
They're not that expensive. I think this is it?
http://www.ebay.co.uk/itm/NEW-Hella-...wAAOSwI-BWHqI2
edit: sorry that one is for D3 not D2 don't know if they're the same.
2010 Audi A8 4.2 TDI
Old 25th November 2015, 01:21 AM
johnny_quattro's Avatar
Default Blinking headlights
Originally Posted by Palmer View Post
Oh bugger!
Expensive fix?
This is a problem that has afflicted my trusty steed for the last two to three months or so. I tried and failed badly in attempting to fix it. Mine is an A8L 2000 FL with Xenons. You can hopefully see from the attached photos that what I suspect to be the ballast is tucked away inside the headlamp housing and I didn't fancy taking that apart, to be honest.
Please feel free to ignore my persuasion tool in the first photo. I use it to whack my Dad on the head when he's not paying attention to me as I bark instructions at him.
ID:	12154   Click image for larger version
Old 1st December 2015, 06:51 AM
Ricky22buk Ricky22buk is offline
Out of curiosity, did the ballast fix it ? I'm just asking because I've been having the same problem for a while. Mine seems to be much worse when it's cold weather than it does when it's warm.
Old 1st December 2015, 07:41 AM
They're actually not that tricky to strip down completely
The control units changed from separate parts mounted in the inner wings to combined units from 2001 - early ones the left one comes out via the wheel arch liner, the right you have to take the headlight out and it's bolted to a panel underneath
From 2001 the units are screwed to the sides of the headlights.
Does it throw a fault code with the light not coming on? If it's J343 or J434 then it's the control unit. If it throws N195 it's the starter unit buried inside the headlight
pdfs attached
Adrian
File Type: pdf gas discharge headlights - starter unit.pdf (84.6 KB, 501 views)
