The knee panel is attached to a small plastic bracket on the transmission side panel so has to come off first. IIRC there are about 5 fixings, two behind the pop-off trim strip below the steering wheel, top right, bottom right and bottom left (onto the bracket)
Even without the 'teats' mine block sometimes (particularly the passenger side), but a poke with a bit of wire clears them easily enough.
Alas my scuttle drains are blocked again!
![]() Just wondering if anyone has any particular recommendations for appropriate chemical additives to very hot water that will dissolve the crud most readily. In the past I've used detergent or washing-up liquid which has worked eventually. So far it's had one small shot of hot water with washing-up liquid and not achieved anything.
http://forum.a8parts.co.uk/showpost....1&postcount=39 Worked great. No problem since and no ill-effects. I would give it a good flush through afterwards, though I think the drain cleaner would have to be left in there for a long time to do any harm.
Thanks, Sodium Hydroxide which isn't good for aluminium? So thorough flushing afterwards.
As it happens we do have some of that stuff in the kitchen.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 9th December 2015 at 12:00 PM. |
![]() I only had about 100ml of it left but just 2 minutes after pouring it in stuff started flowing through. Just going to flush through thoroughly now with a few loads of hot water.
I suspect the thousands of gallons of rainwater that pass through there over the life of the car are probably far more damaging than 30 mins of contact with diluted sodium hydroxide.
![]() Where you've only used a small amount for a short time, you may not have cleared it completely. Hopefully you have, but if it blocks again you might need to leave more of it in there for longer. I keep a spare bottle of it to hand now, but I haven't had to use it since so it seems to do a thorough job.
Indeed, I'll do the same as I expect only one side has actually cleared properly.
Next time (oh the pessimism with D2 drains!) I'll start with the drain cleaner, it does say it's denser than water so sinks to the bottom quickly to start work.
