Old 12th December 2015, 11:30 AM
carmel120 carmel120 is offline
Default any ideas
Address 18: Aux. Heat Labels: None
Control Module Part Number: 4E0 910 105 HW: 4E0 815 069 D
Component and/or Version: Heizgeraet H06 0290
Software Coding: 0000001
Work Shop Code: WSC 00000 000 00000
VCID: D9B3152410E733D633D-808C
Fault Codes have been Erased
1 Fault Found:
02251 - Heater Unit Locked
000 - -
Old 12th December 2015, 12:35 PM
Possible Causes
Fuel Level low
Possible Solutions
When found in Aux Heater module of Audi A8 (4E), unlock heater module by saving a 1 in Adaptation Channel 007, then clear fault codes.
http://wiki.ross-tech.com/wiki/index.php/02251
Matt
Old 12th December 2015, 01:32 PM
Possible Causes
Fuel Level low
Possible Solutions
Old 12th December 2015, 02:38 PM
Did it work?
Matt
Old 12th December 2015, 02:58 PM
i think so i am getting symbols beside the time on the speedo one looks like hot symbol and the other is a fan symbol if that makes sense.
cheers trev
