Old 28th December 2015, 08:31 PM
And there would be four strips of three LEDs each left over to play with.
Are these the ones you can cut short if need by with no problems? The reason I ask is it looks like one could be cut in half.
Old 28th December 2015, 09:36 PM
I tried to explain it earlier in this thread.
Each strip has fifteen LEDs
Each block of three with a resistor are across the two bus bars.
This means that they can be cut in multiples of three and still work.
Electrically, each block is three LEDs and a resistor in series across the 12 volts, then each block is connected in parallel to the others.
Hope that makes sense.
Old 30th December 2015, 01:59 PM
I think you are wasting your time with LEDs from strips. I have several of those strips but LED's are not very powerful, ranging 300 LED's on a 5m long strip for 24W total to 72 LED's for 39W on 1.8m light. On high power chips you can get the same power on single chip. If you are prepared to do some DIY get one of high power COB LED chips. They will need heatsink and do check voltages as many require more than 12V http://www.ebay.co.uk/sch/i.html?_fr...ob+20w&_sop=15
Or CREE MC-E or MK-R chips which will also need heatsinks.
http://www.ebay.co.uk/itm/5pcs-Cree-...v5N6ofVE1S-Dgw
http://www.ebay.co.uk/itm/5x-5W-10W-...qiEXYkXImEPlOw
Old 30th December 2015, 05:03 PM
Thanks Ainar,
I have been playing with these strips but really want to use some CREE LEDs that I have. I just do not want to cause lamp errors. I plan on waiting for better weather to try and find at what current flow level the fault system kicks in and then go from there.
I have the problem of two garages, neither of which are large enough to put the 8 in.
Old 23rd February 2016, 05:23 PM
I finally got around to fitting some T20 LEDs to mine. I already updated to facelift lights but it might be similar for the original style.
The ones I got are perfect brightness and colour quality....
http://www.aliexpress.com/item/1pc-T...370629531.html
First off, they didn't fit in the aperture by about 1mm, so I used a red hot scalpel to remove a bit around the edge of the hole.
Then I put the bulb in, but it stuck out too much for the cover, so have to remove the white wedge base plastic with the hot scalpel and snips.
I put red heat-shrink on the wires sticking out the bulb. I tested and found that the legs with the diodes inline are positive + and these need to go to the connector with yellow single wire rather than the -ve one with a pair of white wires. I held the LED bulb in with a couple of small blobs of white hot glue - I hope it is high enough melting point - maybe sugru would have been better as I do have some.
I was just going to put male lucar ends with solder and shove them into the female lucars but I didn't have the smaller size ones needed.
I took off the white plastic lucar covers and soldered the wires onto the lucars and covered in larger red heatshrink tubing.
Put back in the car tested - everything great and no errors, so put all the nuts and screws and trim back.
Job's a good'n. Hope it's useful. Cost £6ish.
***EDIT*** today I get broken bulb errors on the DIS about a minute after starting off, even when not using the reversing lamps, so will have to put a resistor in
***EDIT*** Today I see that after the broken bulb warning comes on the reversing lights are disabled until next restart - will have to fit a resistor
Old 29th October 2016, 07:38 AM
Turbo Tony's Avatar
Red face
Ever the King of the zombie thread, I thought I'd resurrect another one.
I was looking at LEDs for the reverse lamps too and, having seen different bulbs recommended by different websites, decided to remove the bulbs from my old tail lights to see what they are.
Here's my picture and, although there are now some LED versions showing online, the light output doesn't look great. The best reverse lamps are around 1000 lumens and the only ones I could find were about 600 lumens. Not only that, but they didn't seem to have the connectors in the right place.
Here's a picture of the standard bulb in case anyone's interested.
Here's one of the bulbs I found: http://www.ebay.com/itm/25W-CREE-PH1...-/130968808051
Hope this helps someone. I'll post if I do manage to find any direct replacements, but I'm not holding my breath.
Storytellers Villa Orlando
2008 Audi S8
Old 29th October 2016, 07:52 AM
Turbo Tony's Avatar
Actually, this one looks promising:
It's got the right connections and it uses CREE LEDs. Hmm...
2008 Audi S8
Old 29th October 2016, 08:34 AM
Crees seem to be much more reliable than other LED bulbs, so that's probably a good way to go
Old 29th October 2016, 09:22 AM
Hey Tony,
Don't worry about zombie posts, that is what keeps us going.
You've reawakened my incentive to do this.
Old 29th October 2016, 10:35 AM
Turbo Tony's Avatar
Thanks Ray, I appreciate you saying that.
I'm getting really tempted to pick up a set while I'm in the States and try them out. Even if they don't work, they're not exactly expensive.
I still can't believe what an effort it is to change a bulb in these cars! Remove the bootlid trim, unscrew the three torx screws holding the cover on and then there's still two more to remove the bulb itself! Holy moly, that's a lot of work for something that used to be squeeze clips together to remove the cover, twist off bulb and replace!
Hopefully, it'll be worth the effort. I wish I found these bulbs before I fitted my new lights, would have been much easier on a table.
I'll post my results.
2008 Audi S8
