D2 - Interior Seats, dashboards, plastics, ventilation everything inside the cabin |
With all this rain my car has got chronic misting up of windows, even though there is not much standing water to be seen under the hood and carpets are dry.
Could be the air con, when I switch it on it seems to spew out more moisture? Does anyone have a recommendation for de-humidifiers? Silica gel bag or plug in? I see Halfords sell the bag type for £10 but it seems they are a real pain to dry once full. Someone had one in the oven for 8 hours at 80C and it only removed 14% of the water. Maybe plug-in types are better? |
I use silica gel bags, just dry them on the central heating boiler.
Weigh before use, after absorbing water, then again as they dry. 1Kg bags absorb about 150gm of water quickly, I then dry them. They probably take a lot more.
I think/assume there's a tray that the aircon condensation collects in before it drains away. If it's not draining away properly it's probably staying in the tray for longer, increasing the humidity when you initially turn the aircon on. It might be draining away slowly or, if your aircon is weak or you're not using it much, it might just be evaporating away before it builds up enough to wet your carpets.
Are aircon drains the two drains that run either side of the gearbox?
The ones with orange connectors in each of the front footwells? Thanks |
That's them. Have a container ready to catch the water when you disconnect them, the condensate tray can hold quite a lot (couple of litres maybe)!
But if it was filling up you'd almost certainly be getting the water sloshing and wet feet symptoms as well. You can also end up with water in the pipes that lead to the rear seat ventilation, that's fun! Try all combinations of air outlet (all closed with just one open at a time) on max fan and see if you get any spray. My own experience is that blocked scuttle drains are the ones that result in lots of windscreen condensation, even before they overflow to the interior.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 12th January 2016 at 08:59 AM. |
Thanks, I'll have a look at them. First though is to poke them from under the car without disconnecting internally, if that releases any blockage & water I can avoid removing the carpets.
No sloshing sounds so far. |
I didn't think you could get at them from below, and anyway they tend to need removing and washing out properly..
Passenger side is much easier to get at so do that first. ![]()
Actually, thinking back, I think I've noticed that too, or at least when there's some water beginning to gather in the central area, just below the HVAC intake. Certainly that would be the easiest place to check first since you can usually see any build-up of water there without dismantling anything.
