Old 15th January 2016, 12:29 PM
ulfilias ulfilias is offline
Default Light bulb types / Numbers
Hi There,
Probably a daft thing and i'd guess there is a sticky or something.....But what bulbs fit where ???
And specifically what bulbs fit the side lights. I had an error warning because someone has fitted an LED bulb (passenger) and a standard bulb on the other side. Guess it's throwing the range too, but the beep thing is irrirtating to say the least
Says 241 canbus on it. Not sure its the right size either, despite fitting
Ta,
Lee
Old 15th January 2016, 12:37 PM
Side is W5W-12V5W for all headlights.
I know you've just got your D3, but do you know what headlights you have? Twin halogen, xenon, bi-xenon, cornering?
Matt
Old 15th January 2016, 01:43 PM
Ah....Also know as 501. I have a few of those kicking arround, they just seemed a bit wimpy!
How do I tell what lights i have ???
Old 15th January 2016, 01:59 PM
Conquistador's Avatar
Would imagine it's either twin halogen or xenon with halogen high beams which will both take the same sidelight bulbs as Matty said.
Got any pics of the car now you've got it with you?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 15th January 2016, 02:22 PM
Hi There,
8EC = Bi-functional headlight with gas discharge lamp, for driving on the left
This is what the build sticker says now that i've got a proper photo and had a look at things and stuff
I'm more interested in getting her running straight atm. Irritatingly someone has scratched her in the passenger side too, which i need to sort a bit. There a few things to touch up, sort and stuff but she is certainly fun
Old 15th January 2016, 03:08 PM
Grr....Changed the sidelight and the headlight came out....Now skimming my kncules trying to get it in.....I've looked and it has three straight tabs on the headlamp unit, not hooked tabs on the sticky eg
http://s177.photobucket.com/user/tro...71186.jpg.html
Not that on.....any ideas on what orientation and if they clip, turn or what etc
Ta,
Lee
Old 15th January 2016, 04:15 PM
After a lot of polite asking It finally went in.....Admitedly i'd removed the bulb, lost the retainer, retrieved the retainer (thank goodness for flexie bendy magnetic retrivers), figured out how the retainer went on, cleaned the bulb, put glove on put bulb in, take glove off and fiddle.
Had loosened the reservoir nearby, and done the two torques on the lamps, but it's tight, extra tight with an LPG controller in there too!
I really don't understand why they make a serviceable and legal requiement (particualrly france etc) into such a stupid job!
still got the headlight range warning, but at least the sidelight works properly and theres no semi-constant ding!
(interesting someone has dropped a similar led bulb into the drivers housing down near the bottom.....another day!)
Old 15th January 2016, 04:22 PM
Here's how they change the bulbs on the Q7
Only joking!
Matt
Old 15th January 2016, 08:57 PM
Borys's Avatar
Borys Borys is offline
Brilliant ha ha !!!!
As on every audi
Old 25th January 2016, 09:27 PM
irelandbuyer irelandbuyer is offline
Can I ask a simpleton question....how do i figure out what I have? The lights on mine are like tealights they're so poor....
