No you explained it well enough, thought it was worth checking you didn't have other issues.
http://www.ebay.co.uk/itm/VW-AUDI-EN...8AAOSwNSxVUbKA For that price its worth playing around.
Del ![]() |
Don't think an ecu will help can't imagine the amount of coding involved to switch an ecu. Anybody else know any more about the air system/coding/module??
The Ecu is the difference between sports and normal, sports have no height difference between comfort and dynamic unlike the other controller but do as you see fit.
Del ![]() |
Ok so how easy is it going to be to switch an ecu also won't I lose my remap too?
Delboy the description on your Ebay link didn't make clear it was the air suspension ecu. So I thought your were telling me to buy an engine ECU ok thanks mate great help 👍🏼
The ebay link above is for a level control module. The advert is titled wrongly as an engine ecu, which it isn't, so you wont loose an engine ECU remap.
The level control module should be plug n play, with a bit of VCDS for coding.
Even if you manage to code the 3 heights, the struts are different in SE and Sport.
Audi A8 D3 2006 - 4.2 TDI in Phantom Black |
They are indeed but the S8 that was at the Wales meet from Germany is running a standard controller to enable the different ride heights and I think he has got it just right in regards to heights and practicality
Del ![]() |
Can anyone tell me if these part numbers are for the Quattro sport controller or the SE MODEL?
4E0907553F 4E0910553H |
You've got two numbers there. One is a hardware number, the other is software. Is this from one unit you're looking at?
I can only check the latter 4E0910553H software number. The PR code for this is 1BK 4-corner air suspension with electronic shock absorption control, so this is not the sports variant. However it's best to check with both hardware and software number. Hope that helps ![]()
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 19th February 2016 at 11:35 AM. |
