Hi All
Had any one had this happen. The battery is only about 6 months old and is showing 100% on the meter This happen maybe every 3-4 starts and only on cold starts using the key or start button. Car drives fine and if I tune it off and then back on it goes out. Any tips on where to start looking Thanks very much Steve |
![]() ![]() Is it normal for there to be a small delay on a cold start compaired to a warm or hot start ...just an extra second is what I find. Thanks for getting back to me ![]() Last edited by 3.7 slp; 15th January 2016 at 12:12 PM. |
Is the car used everyday ?
Does it tend to come on after leaving it standing for a few days ? |
Hi yep used every day this happen on a cold start when left overnight
I have seen the epc light come on with no fault codes on some Skoda models , Octavias mainly , on them it has been battery issues ,some kind of low voltage spike , they start ok not like lazy or anything so you would not think it was a battery issue but residual voltage must drop a little low and the ecm just throws a wobbler on the start up
I see you say your car has had a new battery already so you would think it should be ok , could it have a small drain just pulling it down a little . Do you have a battery charger , just as a tester could you run an extension lead into the boot and leave it on a trickle charge just to see if the light still comes on at the cold start , it's something to rule out even if it's not the issue. |
That's a very good point I did have it check out and all good with it. The code that comes up is showing starter not turning when read
Yes was reading your other post about it , if it behaves for the rest of the day with no delay when cranking over its just the first cold start it could be a low voltage thing , defiantly worth leaving on a trickle charge just to see what happens .
All fixed with a new starter motor
![]() thanks for all the tips |
