Old 22nd March 2010, 10:13 AM
Mr K Mr K is offline
they want £1500 for a full rebuild as a worst case scenario
does that include fitting? i.e. roll in, drive out fixed, £1500 lighter? or will there be other costs.
If no other costs £1500 doesnt sound too bad, i had always thought a popped box would set you back £2500 to get it rebuilt and fitted!
Old 22nd March 2010, 10:20 AM
Mr. K here is a breakdown of costs with JT automatics, also comes with a two year/24000 mile warranty. I would think it a good idea to get that quote in writing as well as a note saying they will definitely fix the fault before authorising them to do the work.
Gearbox £895.00
Torque Converter £190.00
Labour £210.00
Fluids £50.00 I would personally get Audi fluid so this might be a little more
Subtotal £1,345.00
VAT at 17.5% £235.38
Total Price £1,580.38
Old 22nd March 2010, 10:50 AM
Thanks Singh, its obviously still a hell of a lot of money and not something you want to happen, but it is atleast not as expensive as i thought.
I hope this gets sorted without needing all that lot, Im gutted for you mate.
Old 22nd March 2010, 10:56 AM
Thanks Mr. K. The £500 AA warranty will help lessen the sting I suppose and if I haggle a little off that £1500 I might be able to get a full box rebuild at a fairly good price. On the plus side, I knew it was going to go one day. Ian once said 'it's a ticking time bomb' once its done I will know it should go on and last and it won't be on the back of my mind if I take it to Germany this year.
Old 22nd March 2010, 11:43 AM
thats the best way to look at it. with the new gearbox and a set of suspension arms, you should have 80-100k with no major shocks.
Old 22nd March 2010, 01:01 PM
A8 Doc A8 Doc is offline
TCM can fail, RS6 ones do. They can be repaired though to bear in mind.
Depends on your budget, if keeping it rebuild entirely.
Old 22nd March 2010, 01:53 PM
entwisi
Guest
Posts: n/a
does sound like a clutch basket as mine did it ( check my posts for pictures of it )
I could drive mine just about but felt like it was stuck in 5th rather than 3rd...
Good luck mate
